37 coupe question. NOW WITH PICTURES!!! #2365246
09/04/17 03:37 PM
09/04/17 03:37 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Did any 37 coupes come with rear seating? Not a rumble seat but inside.
I may be getting one but I need to be able to tote the wife and kids around. Haven't seen th ecar yet but should have pics shortly. I'm completely new to this era so please school me. Can it be done? We're short if that helps whistling
codfish
Re: 37 5 window coupe question [Re: codfish] #2365250
09/04/17 03:42 PM
09/04/17 03:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
there was no room in my 38 5 window coupe for a rear seat.
Don't be the exception.
Re: 37 5 window coupe question [Re: codfish] #2365350
09/04/17 07:09 PM
09/04/17 07:09 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
The only way is jump seats like a 80s s10 had
Re: 37 5 window coupe question [Re: codfish] #2365421
09/04/17 09:01 PM
09/04/17 09:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If we are talking a P4 coupe I don't think so.
2 door sedan, yeah ton of room, you can put a sofa back there, that's essentially what the factory did.
Re: 37 5 window coupe question [Re: Supercuda] #2367570
09/08/17 06:54 PM
09/08/17 06:54 PM
dogdays Offline
dogdays  Offline
Looking at images online I don't see how you could fit seats. You say you're short so you may be able to squeeze two jump seats in there. Three will fit across the front seat if you like each other. It's a fine looking car but a 2-door sedan would work much, much better.
R.
Re: 37 5 window coupe question [Re: codfish] #2367661
09/08/17 11:03 PM
09/08/17 11:03 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I had a 39 Plymouth Business coupe (37-39 are the same basic body). If you pulled the package tray out, backed the separation between the cab and the trunk back, there would be room to put a couple of sideways jump seats there (about 18"). The biggest problem will be the head room. The rear roof has a pretty dramatic angle behind the doors, there is very little space between where the package tray normally sits and the roof line. The jump seats would be useful until the kids started getting tall (read that is their heads reach above the seat back), then they will be sitting with the necks tilted to the side with their heads against the steel roof.
My current car is a 48 Plymouth business coupe. It would have more head room for a rear seat then the 37-39 body, but not much. That is probably why Mopar developed the Club Coupe with a back seat. Those have a much higher rear roof line then the Business coupes do.
2 and 4 door sedans (all years) have a lot of room in the back. Gene
Re: 37 coupe question [Re: poorboy] #2367681
09/08/17 11:52 PM
09/08/17 11:52 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Well here it is. Got it home yesterday.
Re: 37 coupe question [Re: codfish] #2367684
09/08/17 11:54 PM
09/08/17 11:54 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Titled as a 37 Dodge, not Plymouth.
Re: 37 coupe question [Re: codfish] #2367686
09/08/17 11:57 PM
09/08/17 11:57 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Now for the stuff the purists here will not want to see.
Re: 37 coupe question [Re: codfish] #2367699
09/09/17 12:27 AM
09/09/17 12:27 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Running gear from a 96 GM. Fuel injected 350/6 speed. 342 rear. Huge by large MT Sportsmans on the rear. I have 2 sets of fenders and a mint set of running boards with the car, but not painted. Fairly positive the fenders won't house the 31x18.5 15 rubber. Previous owner built it this way. It'll stay like this til I get it on the road and running. Needs a full interior, and I need to find out what the front suspension is outta. I may need to order something to fix the positive camber issue.
Also, he gave me a grill with the car. I'm pretty sure it's a Plymouth grill. I'd hate to cut it up to try and make it fit. Can anyone tell me for sure what this grill is from?
Re: 37 coupe question [Re: codfish] #2367718
09/09/17 12:49 AM
09/09/17 12:49 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
If anyone here with a similar car could share some pics of weather stripping, door jambs, trunk latch areas, trim, headliner, etc I would be greatly appreciative.
Codfish
Re: 37 coupe question [Re: codfish] #2374338
09/21/17 02:58 AM
09/21/17 02:58 AM
Az
Crizila Offline
Crizila  Offline
Az
Codfish
Awesome car! I went with an electric GM style trunk latch. Also included a hidden manual pull release rod so I can open the trunk manually to get to the battery if need be.
Fastest 300
Re: 37 coupe question [Re: codfish] #2374917
09/22/17 10:33 AM
09/22/17 10:33 AM
moparx Online content
moparx  Online Content
looks like the grille that was on my 38 plymouth coupe.
beer
Re: 37 coupe question [Re: moparx] #2376051
09/24/17 08:41 PM
09/24/17 08:41 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
beer
Are 37 and 38 Plymouths the same? The grill that is.
codfish
Re: 37 coupe question [Re: codfish] #2376282
09/25/17 10:20 AM
09/25/17 10:20 AM
beer
codfish
no. 37 and 38 front end parts are different. you can swap the entire assemblies, but not the individual parts.
beer
