Wilwood brakes & front wheel backspacing? UPDATED #236506
02/25/09 11:25 PM
02/25/09 11:25 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I feel like a complete DA. After spending more time on it tonight. I found the real problem. The Shank on the lug nuts was too long. They were bottoming out on the register. Causing to rotor to run out in the caliper. This was binding it all up. Put an extra washer on the lug nuts problem solved. Guess it is time for new lug nuts. Thanks to all who offered advice. Just didn't check it close enough the first time. Jim
Re: Wilwood brakes & front wheel backspacing? UPDATED [Re: rt66jim] #236507
02/26/09 02:42 AM
02/26/09 02:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
I have cut more than one lug nut off to make them fit properly instead of buying new ones, but I'm a little on the cheap side now and then, especially when I'm in a hurry and mad about parts not fitting properly
Re: Wilwood brakes & front wheel backspacing? UPDATED [Re: Cab_Burge] #236508
02/26/09 08:22 AM
02/26/09 08:22 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
never would guessed that after just doing that swap a few weeks ago.oh well easy fix for you.
