Re: Hot Rod Drag Week 2017: The Experience.
[Re: MoparBilly]
#2344500
07/27/17 09:33 PM
07/27/17 09:33 PM
Posts: 1,505 TN
SCATPACK 1
TN
Jerry, Lorelai Grimes showed up on February 20th, then Rachael and Skippy had their marriage ceremony on Apr 29th, even though they took care of the paperwork before the birth.
She's a very happy baby, and hardly ever cries! Since my Grandmother is still alive, as well as Skippy's Great Grandmother, Lorelai makes 5 generations on both sides of the union.
The Belvedere has developed an engine noise, and I haven't delved into it, so it's definitely not going in 2017. With the birth and the wedding, Rachael is out of vacation, but keeps hinting that she'd like to ride along...we will see. I tell her that as a wife and mother, fun time is over now, but she isn't buying it. Billy my friend that is awesome to hear. Glad she and the newby are doing well..
Old Geezer Racing
[Re: MoparBilly]
#2350399
08/07/17 11:58 PM
08/07/17 11:58 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Well apparently James Pranis is going to have to change his Moparts handle from 572Charger to 572ProCharger, as he appears to be leaving the nitrous camp for boost...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2364000
09/02/17 12:20 PM
09/02/17 12:20 PM
MoparBilly
Phoenix, AZ
Ok, Fast 68, they finally broke the 512 out of the Ruster Duster and found the problem. When peering into the cylinders with a borescope they saw what appeared to be a scratch in one cylinder.
When they pulled the piston out, part of the bottom oil ring had been pulled out of it's groove and had been eating into the cylinder wall. Once the block arrived at the machinist it was discovered that cylinder was actually cracked.
Assembly error caused the problem with the ring and led to the crack, or the crack grabbed the ring? Don't know, but the block is getting a sleeve as I type this. Hell Week as officially began!
[Re: Dart451]
#2364039
09/02/17 01:46 PM
09/02/17 01:46 PM
Posts: 14,478 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Feel your pain, thinking the slow 72 fury might being making the trip for us unless we get lucky. Say it ain't so!!
[Re: MoparBilly]
#2364061
09/02/17 02:20 PM
09/02/17 02:20 PM
MoparBilly
Phoenix, AZ
The Gremlin...
He's seriously thinking about running NA this year.
[Re: MoparBilly]
#2364083
09/02/17 02:59 PM
09/02/17 02:59 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Billy if you guys need any batteries or any help let me know. I work by the track so Owasso isn't to far for me to help out for an evening or two. I'll PM you my number
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: MoparBilly]
#2364110
09/02/17 03:30 PM
09/02/17 03:30 PM
MoparBilly
Phoenix, AZ
Thanks Clark.
Yeah, tunnel ram is new, and the carbs won't clear his little bolt on cowl scoop, so the Gremlin will have a different look this year. 580 inches, Indy -1 heads opened up to 355cc, 760ish roller. Good tractor engine.
[Re: fast68plymouth]
#2364213
09/02/17 08:17 PM
09/02/17 08:17 PM
Posts: 666 IL
Dart451
IL
Feel your pain, thinking the slow 72 fury might being making the trip for us unless we get lucky. Say it ain't so!! Will see what I can get done, about to go start removing the trans now. Still need to get windows removeable and figure out a hitch and a small trailer to take extra tires. Road tuning will be on dragweek, Did get o2 hooked up friday before we went to the track. Car was a tenth off with new tires. My job is busy and going thru a corperate reorg also, and thats never good. Back to the orginal story, sorry for hyjack
[Re: MoparBilly]
#2364548
09/03/17 01:29 PM
09/03/17 01:29 PM
MoparBilly
Phoenix, AZ
Boone's 511. Block made it back from the machinist with a new sleeve Friday afternoon. They reassembled the short block with a new oil ring, but something was still scratching the bore. Removed the offending piston, and realized the expander was damaged. Before you ask, yes, Dale is so cheap that he tried to replace one oil ring in that hole instead of replacing the whole ring pack on that piston!
Since they've decided to go roller cam, they needed to switch everything over on the heads, then discovered the rockers needed clearancing to fit the new retainers. Engine started going back in the car Saturday night.
They probably would have had it fired last night, but just like at Drag Week last year, Little Billy just can't hang!
[Re: MoparBilly]
#2364606
09/03/17 02:41 PM
09/03/17 02:41 PM
fast68plymouth
So. Burlington, Vt.
Holy crap!!! Does that mean there are now two roller cams in the G Clan?
#2364832
09/03/17 09:04 PM
09/03/17 09:04 PM
Posts: 10,009 MN
JERICOGTX
MN
Joel and I have been working away on his coupe. We are WAY behind. Joel is finding out that wiring the car at the last minute isn't a good plan.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2364836
09/03/17 09:11 PM
09/03/17 09:11 PM
Posts: 10,009 MN
JERICOGTX
MN
Of course in these photos you can see Joel's natural position. "Are you sure you did that right?".
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2364839
09/03/17 09:13 PM
09/03/17 09:13 PM
Posts: 10,009 MN
JERICOGTX
MN
But one way or another we will make it to Drag Week 2017...
69 GTX
68 Road Runner
[Re: MoparBilly]
#2364929
09/04/17 12:42 AM
09/04/17 12:42 AM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
Is the battery charger on the convertible yet??
I am going to try to make it out to Great Lakes Dragaway. I've heard the turnout was stellar in previous years for Drag Week!
