W9 Rocker Stand hardware #236280
02/25/09 08:12 PM
02/25/09 08:12 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I called ARP two weeks ago and ordered W9 rocker stand hold down bolts. The guy said he'd get it out. Called them today to see what was up. The guy I talked to said there is no kit, and nothing was ever sent out. I need to know what size and length these bolts are and if they have a special head.
I can't believe they don't have a kit for this. What do you guys tell them when you order stuff?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: W9 Rocker Stand hardware [Re: DemonDust] #236281
02/25/09 10:22 PM
02/25/09 10:22 PM
Menomonee Falls
Menomonee Falls
All you guys with W9 heads and no one has any bolts laying around
SDG Motorsports
Re: W9 Rocker Stand hardware [Re: DemonDust] #236282
02/25/09 10:26 PM
02/25/09 10:26 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
DUUUHHHHH.....I would bet your local hardware stor would have grade 8 bolts in the lenth/size you would need....do you not have the additional parts to just get a measurement.....
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: W9 Rocker Stand hardware [Re: DemonDust] #236283
02/25/09 10:27 PM
02/25/09 10:27 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call T&D that is where I got my bolts from for my stands
Re: W9 Rocker Stand hardware [Re: instigator] #236284
02/25/09 10:30 PM
02/25/09 10:30 PM
Menomonee Falls
Menomonee Falls
I don't have heads or anything. I'm getting these for someone that needs them.
So I have no reference.
SDG Motorsports
Re: W9 Rocker Stand hardware [Re: scottb] #236285
02/25/09 10:32 PM
02/25/09 10:32 PM
Menomonee Falls
Menomonee Falls
Ok I'll give them a try...
SDG Motorsports
Re: W9 Rocker Stand hardware [Re: scottb] #236286
02/25/09 10:32 PM
02/25/09 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine came with the TD set, but they are 3/8 course
X 1 1/4 or 1 1/2 with a 12 point head
Re: W9 Rocker Stand hardware [Re: MR_P_BODY] #236287
02/25/09 10:34 PM
02/25/09 10:34 PM
Menomonee Falls
Menomonee Falls
Thanks. How many do they take?
SDG Motorsports
Re: W9 Rocker Stand hardware [Re: DemonDust] #236288
02/25/09 10:44 PM
02/25/09 10:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
8 per head
Re: W9 Rocker Stand hardware [Re: MR_P_BODY] #236289
02/25/09 11:27 PM
02/25/09 11:27 PM
Menomonee Falls
Menomonee Falls
8 per head
Thanks for the all the help.
SDG Motorsports
Re: W9 Rocker Stand hardware [Re: MR_P_BODY] #236290
02/26/09 09:45 AM
02/26/09 09:45 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
W9 is 7/16" Coarse....... You have to use the appropriate brand for the appropriate stand, ie. T&D stand bolts will not fit on a Jesel stand. (too tall of bolt head)
ARP just supplies Jesel/T&D with bolts, they have no idea what they are using them for, so no they would not know which bolts are correct & most likely have a proprietary deal with each company that you can not buy their rocker stand hardware through them (must buy direct form Jesel or T&D etc)
Re: W9 Rocker Stand hardware [Re: RyanJ] #236291
02/26/09 09:54 AM
02/26/09 09:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
WOW, I didnt have any bolts around to look at but I
didnt think they were that big(dia)... thanks for
the catch Ryan. I want to put a stud in mine just so
I dont have to put the bolts in the same hole all the time
.... as I contoured the bolts to the runners
Re: W9 Rocker Stand hardware [Re: MR_P_BODY] #236292
02/26/09 10:33 AM
02/26/09 10:33 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
W2/W5/INDY etc = 3/8"-16
W7/W8/W9 = 7/16"-14
W9RP & Some Lazy W W7 stuff uses a couple 3/8's per bar.
Re: W9 Rocker Stand hardware [Re: RyanJ] #236293
02/26/09 10:43 AM
02/26/09 10:43 AM
Menomonee Falls
Menomonee Falls
W7/W8/W9 = 7/16"-14
Thanks for the update Ryan
SDG Motorsports
