Re: Removing key cylinder from glove box??
[Re: 70HemiGTX]
#2361362
08/28/17 08:19 PM
08/28/17 08:19 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
Sorry I do not have the key that belongs to the door. that means that you need to have a key made or you will be breaking it..
[Re: 70HemiGTX]
#2361633
08/29/17 11:00 AM
08/29/17 11:00 AM
Posts: 1,822 Colorado
denfireguy
Colorado
If you have the matching trunk lock, it is easier to remove it and take it to a locksmith and have a key made. I am guessing you don't though. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 70HemiGTX]
#2361645
08/29/17 11:20 AM
08/29/17 11:20 AM
Posts: 3,544 Lansing, MI
70gtx440dana
Lansing, MI
I have had great luck just popping the chrome piece off of the lock housing. A flat screw driver inserted slightly into it, and then a bit of a pry will pop it right off. Very easy to press on again too. I just use my vice and a socket that fits over the chrome piece with a rag in between. I have done several like this. I tried to get mine off with procedure shown above. Must have had an hour or more into it and gave up. My method took about 10 seconds. Good luck!!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
