Page 5 of 6 < 1 2 3 4 5 6 >
#2304556 - 05/14/17 08:34 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
Loc: tri-cities Washington/Denver, ...
fender gaps are going to need some attention...
#2304559 - 05/14/17 08:39 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
poorboy Offline
Loc: Freeport IL USA
#2304568 - 05/14/17 08:46 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
poorboy Offline
As much as I hate to say it, it looks like the front of the nose needs to come down to align the fenders and door gaps. That will make the hood clearance even worse.
How close is the hood to throttle body, and is it just the throttle body, or the intake as well? Will you have clearance for an air filter assembly? Maybe if its just the throttle body clearance, you can add a tapered shim between the intake and the throttle body to gain the clearance you need. Gene
#2304752 - 05/15/17 08:04 AM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
Mike P Offline
Loc: AZ
Oh man I can truly sympathize. I had exactly the same problem on my 57 when I put the Hemi in. The slope on the hood interfered with the front of the air cleaner for the Tri-Power. In my case it was either lose the Tri-Power for a shorter intake or use a hood scoop.
I agonized over that for about a month (especially as IMO there are no scoops that really look good on these cars). In my case the Tri-Power won and I sacrificed a 61 Thunderbird hood for the scoop.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10)
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56)
#2305246 - 05/15/17 10:12 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: Mike P]
5280Dart Offline
Well for what it is worth, it looks good. I actually was trying to figure out what you used....
Kinda leaning toward a 1969 dodge power bulge.... I am going to contact some of the supercharger manufactures and hope that they offer a unit for the 6.1 with about an inch less total height than the srt intake manifold. I briefly considered a 1" body lift, and then a corresponding 1" suspension drop. Dont really want to go that route.
#2323396 - 06/18/17 11:10 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
Starting to install the wiring harness...
#2323398 - 06/18/17 11:12 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
Trying to find a place for all the stuff is a bit of work...
#2323399 - 06/18/17 11:15 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
Had to cut a 2.375" hole in the firewall, behind the passenger side fuel rail for the harness to pass thru. There is a portion of the harness that has to be snaked under the intake manifold, cam sensor, water temp, a/c pump, etc. That took some doing.
#2324401 - 06/20/17 07:53 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
challenger73400 Offline
Loc: southwest Alabama
Looking good! Can't wait to see that thing finished!
#2360699 - 08/27/17 04:17 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
#2360806 - 08/27/17 07:23 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
Satilite73 Online   work
Loc: Between Houston & Galveston TX
Originally Posted By 5280Dart
thumbs
John
#2361010 - 08/28/17 04:48 AM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
Mike P Offline
Loc: AZ
Great to see/hear it run! Did you come up with a hood clearance solution?
#2361591 - 08/29/17 08:12 AM Re: dodge dakota frame swap, custom coils or air bags needed [Re: Mike P]
5280Dart Offline
No solution on the hood just yet.
#2496232 - 05/14/18 10:05 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
Well, time for an update. Here is my hood clearance solution...
Edited by 5280Dart (05/14/18 10:05 PM)
#2496233 - 05/14/18 10:06 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
#2496237 - 05/14/18 10:14 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
I had to deepen the driveshaft tunnel due to the need for a larger diameter driveshaft, lowered stance, and the elevated install height of the transmission.
Edited by 5280Dart (05/14/18 10:15 PM)
#2496243 - 05/14/18 10:18 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
I am running 3" exhaust all the way back, with an H-pipe and Dynomax Ultraflo mufflers...
#2496247 - 05/14/18 10:21 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
5280Dart Offline
And I swapped in a 8.8 ford rear end out of a 1998 ford explorer. That provided 3:73 gears, tracloc differential, 31 spline axles, and disc brakes for the low cost of $300.
#2496478 - 05/15/18 12:58 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
Awesome!
#2496513 - 05/15/18 02:09 PM Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart]
67R/T4speeder Offline
Loc: Pismo Beach,California
Nice work
Andy
www.troxellsgarage.com
25,492 Registered Members
193,092 Topics
Vintage Air’s Rick Love To Moderate SEMA HR Builder’s Panel
by Rustymuscle
09/24/18 08:55 AM
Sundowner car trailers
by d330
09/24/18 07:41 AM
1969 Plymouth Road Runner
by tomsjack
09/24/18 03:37 AM
what app uses a 5/16 (.312") 2.02 intake valve
by RapidRobert
09/24/18 01:04 AM
