Removing key cylinder from glove box?? #2361340
08/28/17 08:40 PM
08/28/17 08:40 PM
PA
70HemiGTX Offline OP
PA
I missed the class on how to remove the lock and key cylinder from the glove box door from a 70 b-body. Sorry I do not have the key that belongs to the door. So short of breaking the things what must I do? I assume I need to push the small spring that is half way down the housing into the grove and then pull the cylinder out??? Thanks!
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361344
08/28/17 08:51 PM
08/28/17 08:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...one of these should help? last instructions is for E body
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361362
08/28/17 09:19 PM
08/28/17 09:19 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that means that you need to have a key made
or you will be breaking it..
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361363
08/28/17 09:19 PM
08/28/17 09:19 PM
BDW Online content
BDW  Online Content
I just went through this, you can't remove it without it in the locked position.
So you need key or a way to pick the lock.
Locksmith wanted $50 to do it, so I just drilled it out and replaced with a non-locking cylinder.
You can buy a brand new repo keyed lock cylinder for $30.
Re: Removing key cylinder from glove box?? [Re: BDW] #2361435
08/28/17 11:10 PM
08/28/17 11:10 PM
PA
PA
Thanks for all the insight. I don't care about breaking the chrome trim part. I have a new set to put in. I just don't want to harm the inside latch. I guess I need to break out the drill.
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361452
08/28/17 11:32 PM
08/28/17 11:32 PM
IN
ahy Offline
ahy  Offline
IN
FWIW I tried to remove the lock on mine with the FSM procedure... in unlocked condition with key. No go. Perhaps operator error? In any case, I re-finished around the lock. Masking tape and time was my friend. It came out fine.
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361462
08/28/17 11:49 PM
08/28/17 11:49 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i have taken a few apart that were not easy to do.
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361633
08/29/17 12:00 PM
08/29/17 12:00 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If you have the matching trunk lock, it is easier to remove it and take it to a locksmith and have a key made.
I am guessing you don't though.
Craig
Re: Removing key cylinder from glove box?? [Re: denfireguy] #2361638
08/29/17 12:05 PM
08/29/17 12:05 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Had same problem (no key) took it out and took to locksmith. I think he charged 8 bucks to make a key.
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361645
08/29/17 12:20 PM
08/29/17 12:20 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have had great luck just popping the chrome piece off of the lock housing. A flat screw driver inserted slightly into it, and then a bit of a pry will pop it right off. Very easy to press on again too. I just use my vice and a socket that fits over the chrome piece with a rag in between. I have done several like this. I tried to get mine off with procedure shown above. Must have had an hour or more into it and gave up. My method took about 10 seconds. Good luck!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Removing key cylinder from glove box?? [Re: 70HemiGTX] #2361856
08/29/17 06:57 PM
08/29/17 06:57 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Could you remove door and take to a knowledgeable locksmith who could 'impression' a key. My ex father-in-law would often impression door locks on locked out Mopars
Re: Removing key cylinder from glove box?? [Re: Sxrxrnr] #2362565
08/30/17 10:21 PM
08/30/17 10:21 PM
PA
PA
I got it off pretty quickly with the paper clip. Even without the key. I just used a small flat screw driver to wiggle a little bit. Then it just started to work it's way out. Now to refinish everything...
