coil over springs #2361069
08/28/17 11:38 AM
08/28/17 11:38 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
A while back there was a discussion on choosing the correct spring for a coil over. If memory serves, this is the short version:
1 install the recommended length spring on the shock
2 using the threaded adjuster, compress the spring 1 inch
3 install the shock on the vehicle and set it on the ground
4 if the spring is correct, the shock will now be at manufacturer's recommended installed length.
Is this correct? or am I way off base?
Thanks for your input bow
Re: coil over springs [Re: cagebob1] #2361077
08/28/17 11:51 AM
08/28/17 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You are correct... that gives you 1" of
movement each way
wave
