1970 Road Runner #2361007
08/28/17 06:30 AM
08/28/17 06:30 AM
USA
StangGangRepair Offline OP
USA
Hello...
I was pointed to this forum looking for help with a plymouth road runner. We have been in the process of restoring one for a friend of our shop owner but having problems with the rear window. He didn't have many parts including a back window so we ordered a window from our local glass supplier but the one shipped in doesn't fit and its the only brand they can get. Where is a good place to get a window that fits properly? Who make the best glass for plymouths?
Thank you for your help
Re: 1970 Road Runner [Re: StangGangRepair] #2361032
08/28/17 10:24 AM
08/28/17 10:24 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
ECS Automotive for OEM. Several suppliers on Ebay.
DD
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 1970 Road Runner [Re: StangGangRepair] #2552847
09/21/18 01:51 PM
09/21/18 01:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Better double check to make sure that you buddies Road Runner may not be an old Superbird with the different rear window design.
I have a 70' Road Runner also. I can measure the window where ever needed for you if you need any dimensions to compare to your new rear window?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1970 Road Runner [Re: StangGangRepair] #2553296
09/22/18 05:26 PM
09/22/18 05:26 PM
Arizona
AzMoparMike Offline
AzMoparMike  Offline
Arizona
Here is a picture of the window you need.
Re: 1970 Road Runner [Re: StangGangRepair] #2553915
09/24/18 12:17 AM
09/24/18 12:17 AM
USA
USA
Thank you for the recent reply and pictures of the window. I believe that looks like the one we tried but it didn't fit with the bottom curves. This post was over a year ago and the owner of this car has since moved on to a 67 Stang Fastback, something we are more familiar with and it will be more nasty with the 428!
Re: 1970 Road Runner [Re: StangGangRepair] #2553933
09/24/18 01:32 AM
09/24/18 01:32 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Probably had the corners replaced with crappy repops... I know this is an old post, but the corner repair pieces they used to sell were flat and worthless.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1970 Road Runner [Re: StangGangRepair] #2554209
09/24/18 08:19 PM
09/24/18 08:19 PM
cbusters Offline
cbusters  Offline
If the dutchman panel was replaced without having a back window to fit then the bottom of the backlite opening is likely too narrow. It may not be the glass.
Re: 1970 Road Runner [Re: cbusters] #2555655
09/27/18 07:27 PM
09/27/18 07:27 PM
People's Republic of Kali
70runner Offline
70runner  Offline
iagree
Likely the glass is correct. We replaced the dutchman panel on my 70RR vert with an NOS piece and the OE convertible well trim did not fit on the corners. We had to massage the dutchman to align with the corner trim.
Re: 1970 Road Runner [Re: 70runner] #2577690
11/12/18 11:19 PM
11/12/18 11:19 PM
USA
USA
70Runner and cbusters, I think you were right about the dutchman panel being replaced wrong. As I was loading it up to be shipped out, I removed the old carpet from the package tray and i can see somebody's crappy work. Looks like they just welded a new dutchman panel over top of the old dutchman panel as i can see the bottom of the old window rail once the carpet was removed. At least it is now somebody elses headache. Ill attach a pic for you to see this crap.
Thanks for all your help though and next time I get a dodge in here, I will reach out to this forum again before i buy 3 windows that wont fit!
Thanks Again!
Re: 1970 Road Runner [Re: StangGangRepair] #2577754
11/13/18 12:56 AM
11/13/18 12:56 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks Again!
That's a Superbird rear window plug installed over the stock dutchman panel, that's the way they were done, now you've opened Pandora's box for the popcorn crowd...
AMD has repro rear windows for 70 SUPERBIRDs.... retail is approx $950 IIRC...better hurry if you truly need it as it's a limited run, the rear window trim is available as well...$850, IIRC they have a package deal, window and trim for approx $1500
Re: 1970 Road Runner [Re: DAYCLONA] #2577760
11/13/18 01:17 AM
11/13/18 01:17 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Thanks Again!
Yep that's Pandora's box right there. LOL
Re: 1970 Road Runner [Re: StangGangRepair] #2577809
11/13/18 03:40 AM
11/13/18 03:40 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I never knew they installed them over top like that... never worked on one. I've seen clones where people don't even install the plugs work
Re: 1970 Road Runner [Re: Silver70] #2577865
11/13/18 12:16 PM
11/13/18 12:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 69 Charger Daytona and 69 Charger 500 models are done the same way also, the stock dutchman stayed in place and was covered over by the Aero plug install
Mike
Re: 1970 Road Runner [Re: DAYCLONA] #2578263
11/14/18 05:42 AM
11/14/18 05:42 AM
USA
USA
Dayclona,
Thanks for the info on the rear window but we got rid of that car a few weeks ago after all the troubles with the rear window and other other parts. Thats a pricey window but I wish I would have talked to over a year ago when we first started having issues with the window. Im glad to see that one go.
Re: 1970 Road Runner [Re: StangGangRepair] #2578286
11/14/18 10:55 AM
11/14/18 10:55 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Dayclona,
Yep, seriously! Lol. This would be the equivalent of going on to a Mustang board and complaining about not being able to find a hood that looks just like the one on my Mustang so I kicked on down the road. Oh, and it had someone name on the car too, like Shelley or something like that. He might have had a Superbird with a RR front end. Who knows now.
Re: 1970 Road Runner [Re: fastmark] #2578313
11/14/18 12:20 PM
11/14/18 12:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dayclona,
Never know?... This could be the beginning of one of those stories you hear about some Chevy/Ford guy(s) who unknowingly had a potential 6 figure car in their hands and let it go for reasons like above...probably had some engine mods that looked like someone drilled holes in the valve covers to fit the ignition wires through too?...lol!
Re: 1970 Road Runner [Re: DAYCLONA] #2578950
11/15/18 10:14 PM
11/15/18 10:14 PM
Chicago
PurpleBeeper Offline
Chicago
Thanks Again!
Holy Super Bird Batman! So.....is it possible this Roadrunner was one of those 70 Superbirds that didn't sell & had the nose removed???
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 1970 Road Runner [Re: PurpleBeeper] #2588428
12/07/18 02:44 AM
12/07/18 02:44 AM
Arizona
AzMoparMike Offline
AzMoparMike  Offline
Arizona
After this post sat here for over a year, I offered help with the window. No need to start rumors here about it being sold as a RR without a nose. It was just s SB missing the nose, passenger fender, hood and horizontal stabilizer. When I was emailed pics of the window I suspected what it was and made a very reasonable offer to obtain this project for someday down the road when I have time. If anyone has any of the missing parts I mentioned, I would be interested in them.
