"Full floater" Ford 8.8" vs. Mopar 8.75"
#2359506
08/25/17 09:47 AM
08/25/17 09:47 AM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
Looking over Moser's complete axle assembly offerings, it looks like their M88 (Ford 8.8 style) autocross/full floating axle assembly will cost about the same or a bit less than a Mopar 8.75 style assembly. Either can be had at custom widths, spring perches welded, etc. Both weigh about the same.
The advantages of a full floating axle are only now something that have become aware of and the M88 is starting to look a bit more appealing with the idea of enjoying the car on winding roads and the occasional autocross course.
Then again, the Mopar style 8.75" is well known for being strong, reliable and convenient for ratio swapping...
Any reason to pick one over the other?
Second, which limited slip type would be most beneficial for a corner-carver? It looks like there are a few choices on either axle.
Thanks for any thoughts. -Mike
Re: "Full floater" Ford 8.8" vs. Mopar 8.75"
[Re: jcc]
#2359517
08/25/17 10:19 AM
08/25/17 10:19 AM
MRGTX
Connecticut, USA
Well...ok. Do guys build these? I don't see an option for the complete bolt-in assembly; at leas not from Moser.
[Re: MRGTX]
#2359842
08/25/17 07:46 PM
08/25/17 07:46 PM
Posts: 22,695 Bitopia
jcc
Bitopia
No, until you drive cross country with nice 2.76 gear, arrive late to a track event, and wish you could swap in that 3.55, by just drain the fluid, slide the floater axles out a few inches, swap third members, and on the track.
[Re: MRGTX]
#2361642
08/29/17 12:14 PM
08/29/17 12:14 PM
Posts: 5,386 Pikes Peak Country
TC@HP2
Pikes Peak Country
It is probably true that non-floating axles experience more heavy side loading and wear. However, any number of us on here have mercilessly abused the 8.75 rear over the decades without detriment. Can they break, sure, but in many cases they are more than adequate for the application, especially when they are not being shock loaded like in a drag racing environment.
I have used them in oval track and drag racing since the '80s. I've never broken one, but I've also never dealt with more than 400-425 horse mills, and even with that I used a spool and 35 spline axles in my drag application. Since this was using slicks on a prepared track, I thought it a wise investment. On oval tracks, I used standard axles and sure grips. This has been both with treaded and slick tires. However, oval tracks never approach the level of grip you find on the starting line of a drag strip.
Will the 8.75 stand up to autocross, IMO, absolutely. Are there better components out there than stock, also affirmative. I've got no experience with the Eaton Truetrac but it looks like a good piece. To me, an axle swap at a later date is not a big deal that would require a lot of effort. If you want to upgrade now in anticipation of future power levels, you certainly could or you can wait until later. It all depends on your budget, effort you're willing to put in, power levels, and application.
[Re: MRGTX]
#2361668
08/29/17 12:56 PM
08/29/17 12:56 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I have a 8.8 in my 64 Fairlane that started out in an Explorer, narrowing 2" with 9" axles, carbon fiber cluch kit, Moser yoke and the cost of the used assembly I have $900 in it. The thing I like about it the cost and availability of parts.
I have a 8 3/4 in my Plymouth, the ability to change gears is nice but centers are getting harder to find and are fifty years old.
I'd go with a Dana, Ford 9" or 8.8.
Have a great day Iowan
"obsolete is neat"
[Re: MRGTX]
#2361787
08/29/17 04:16 PM
08/29/17 04:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can get brand new centers for the 8.75.
But honestly, how many of us swap out center sections and how of us that do, how may extra center sections do you have>
I'll bet few and one, maybe two extras.
[Re: MRGTX]
#2361795
08/29/17 04:32 PM
08/29/17 04:32 PM
Iowan
Lost in Time
Don't get me wrong, I like the 8 3/4, know I have red where the stock 9" is weaker than the 8 3/4 and a stock 9" is as strong as a 8.8... But there's stock 8.8s in the 9s and 8s.
How many stock 9" or 8 3/4 ZERO...... GO FIGURE!
"obsolete is neat"
[Re: Supercuda]
#2361806
08/29/17 05:22 PM
08/29/17 05:22 PM
jcc
Bitopia
I'll bet few and one, maybe two extras. But the the upside of the OP's question, with a full floater, its almost easy to swap out, and you only need one extra 8.75 to make that happen, although more is nice.
[Re: MRGTX]
#2361925
08/29/17 08:52 PM
08/29/17 08:52 PM
Supercuda
About to go away
About to go away
up yours
Seriously? Running 9's?
Wrong forum.
