#2296187 - 04/29/17 05:25 PM Mounting 57 Plymouth on Rotisserie?
HemiSportFury Offline
Loc: State That's Gone to Pot
I'm getting ready to put my 57 Plymouth on a rotisserie (Whirley Jig). I will use spacers to raise the body 4" off the frame and then attach the frame to the rotisserie. I've done several B-bodies, but this is the first full frame vehicle I have put on one. Does anyone have some pictures of how you attached your full frame car to a rotisserie? I will use the bumper attaching points and have to fab some sort of an attachment bracket. Just looking for ideas.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'64 Sport Fury, 383, 4-speed
'57 Belvedere 2dr sedan, current project in process
'14 Rubicon Unlimited
'03 Ram 2500 CTD HO, 6-speed
#2297779 - 05/02/17 01:49 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: HemiSportFury]
1DGEMAN Offline
Loc: TN and CA
My Whirley Jig came with a video that showed how to put a full frame vehicle on the rotisserie. They sold some spacers to help with the job. You might try contacting them.
Real Men shift for themselves
#2297824 - 05/02/17 03:09 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: HemiSportFury]
19swinger70 Offline
Loc: Richmond, Indiana
Not sure what exactly you are looking for. Here are pics of my '55 on the rotisserie.
I have more pics if you want a specific detail.
1970 340 swinger. sublime 1967 barracuda fastback BB project 55 Plymouth Project
#2297883 - 05/02/17 05:23 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: 19swinger70]
Old Ray Offline
Loc: British Columbia, Canada
Originally Posted By 19swinger70
Not sure what exactly you are looking for. Here are pics of my '55 on the rotisserie. I have more pics if you want a specific detail.
Thank you for posting, very helpful to me as well. up
#2298101 - 05/03/17 12:33 AM Re: Mounting 57 Plymouth on Rotisserie? [Re: 1DGEMAN]
I did contact them and bought the spacers from them. Video had long since been lost (I bought my whirley jig in '99). We discussed in general and I have a pretty good idea what to do but can always learn from what others have done.
#2298173 - 05/03/17 08:50 AM Re: Mounting 57 Plymouth on Rotisserie? [Re: HemiSportFury]
19swinger70 Offline
The trickiest part for me was getting it off the frame and onto the rotisserie. The body mounts are easy to bolt to - even if you need to use a spacer.
I used an engine puller on the rear, while lifting the front of the body with my loader tractor.
Also, I had to fix the rear body mounts before I could use them to bolt to the rotisserie. Check yours!
#2308779 - 05/21/17 08:22 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: HemiSportFury]
bboogieart Offline
Loc: Lost and Spaced
Looks like he is wanting to leave the body on the frame.
I have mechanical Aptitude.
I can screw up anything.
#2319891 - 06/12/17 12:06 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: bboogieart]
wayfarer Offline
Loc: Central Ory-gun
...that will add a huge amount of dead weight that I would try to avoid.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
Machine shop services
#2330336 - 07/02/17 06:26 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: wayfarer]
bboogieart Offline
just saying...
shruggy
No response since.
whistling
#2333707 - 07/08/17 03:36 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: bboogieart]
just saying...
shruggy
No response since.
whistling
Been away for several weeks so no chance to respond. I'm going to use spacers to raise the body off the frame, but mount it with the frame so I will not need to add stiffeners to the body. This is the way Whirley Jig recommended doing it. Since a 57 Belvedere weighs a little less than a b-body, keeping the frame on should not weigh much different than the b-bodies I have done. I have pretty well figured out how to fab the brackets to attach to the frame, so now it's just a matter of finding the time. Still working on fabbing motor and trans mounts before I put it on the rotisserie.
Thanks for all the suggestions. Gave me good ides.
#2352319 - 08/11/17 08:06 AM Re: Mounting 57 Plymouth on Rotisserie? [Re: wayfarer]
1DGEMAN Offline
Loc: TN and CA
As in my original response. They have video of how to do this. There is a reason to leave the body attached to the frame.
#2352932 - 08/12/17 04:29 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: 1DGEMAN]
Got it mounted on the rotisserie with the spaces holding the body 5" above the frame. It is very well balanced this way and easy rotate. When I'm working on the frame only I will probably have to flip the mounting points to get a reasonable balance point.
#2353193 - 08/13/17 11:51 AM Re: Mounting 57 Plymouth on Rotisserie? [Re: HemiSportFury]
wayfarer Offline
Very good to see that it is working out for you!
#2355669 - 08/17/17 06:59 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: wayfarer]
bboogieart Offline
Ditto. up
#2358747 - 08/23/17 06:39 PM Re: Mounting 57 Plymouth on Rotisserie? [Re: bboogieart]
dogdays Offline
It's going to take a whole lot of LP gas to barbecue that thing!
R.
25,151 Registered Members
186,842 Topics
Where to buy M&H wiring? Year one ? Classic?
by fuelishnsilly
02/24/18 08:42 PM
451 builders...show your combos !
by Wedgeman
02/24/18 08:06 PM
Upper Control Arm Bushing Tool
by DoctorDiff
02/24/18 07:49 PM
Ye Olde shop doors circa 1880 for the antique lovers
by Alaskan_TA
02/24/18 07:29 PM
