Re: KB blocks
[Re: Biginchmopar]
#2358338
08/22/17 10:30 PM
08/22/17 10:30 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I made a mistake and didn't order my Keith Black RB block for pushrod oiling so I had a local shop (Tom Hemphill) drill it for me so I could run both my 440-1 heads and B1 heads.
Re: KB blocks
[Re: camastomcat]
#2359290
08/24/17 08:06 PM
08/24/17 08:06 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Depends on common shaft rockers or paired rockers. I would never run spray bars with single shaft rockers. The only way to fix it with single shafts is to drill the oil passage in the block from the cam to the heads.
Re: KB blocks
[Re: perfmachst]
#2361005
08/28/17 04:56 AM
08/28/17 04:56 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
OR you can make individual lines to every lifter bore, which is propably easier and less expensive and can even be done at home.
Plynouth VIP '67 TT IC EFI
