Hood hinge 69 A body
#2358282
08/22/17 08:33 PM
08/22/17 08:33 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
The drivers side hood does not go all the way down on back side of hood where the hinge is mounted. Just started doing this. After you close the hood, the back is stuck up about an inch and you can push it down with your hand. What's the cure?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Hood hinge 69 A body
[Re: stumpy]
#2358303
08/22/17 09:10 PM
08/22/17 09:10 PM
6T9Hemi
Elizabethtown, KY
What's would be the best lube for that style hinge?
