Hood hinge 69 A body #2358282
08/22/17 08:33 PM
08/22/17 08:33 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
The drivers side hood does not go all the way down on back side of hood where the hinge is mounted. Just started doing this. After you close the hood, the back is stuck up about an inch and you can push it down with your hand. What's the cure?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2358293
08/22/17 08:43 PM
08/22/17 08:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lubricate the hinge.
Re: Hood hinge 69 A body [Re: stumpy] #2358303
08/22/17 09:10 PM
08/22/17 09:10 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What's would be the best lube for that style hinge?
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2358464
08/23/17 09:50 AM
08/23/17 09:50 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Be cautious when closing the hood just in case the hinge is shot. Don't want it to bind and bend the hood with lots of pressure. I've heard regular motor oil, to silicone spray, to WD-40. I have some Endura Penetrating Grease I am going to use on mine. Someone on here recommended it for door hinges, so I got a can from Amazon.
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2358599
08/23/17 03:01 PM
08/23/17 03:01 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Hood hinge bolts loose or hood hinge area rusty? They tend to rust in the hinge area from the inside out and weakens the clamping force. Then the hood slides around. Witnesss marks on hood?
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2358637
08/23/17 04:39 PM
08/23/17 04:39 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
On My A-body it did that until I adjusted the hinge better. If nothing is rusted or bent you may need to adjust how the hinge is connected.
I think (if I remember)that you move the rear of the hinge up on the hood.
Anyway, I sounds like an adjustment to me. I does need it's lubrication as well.
