HEMI inline dual quad intake....
#23582
03/06/06 10:40 PM
03/06/06 10:40 PM
I'm looking for a dual quad intake for a HEMI. Both Mancini and SUMMIT list it. P4510633. Does one have to have a "code", or do I ask for Wes, and get the "friendly" deal?? Summit is now $10.00 higher.
Re: HEMI inline dual quad intake....
[Re: domingo]
#23588
03/07/06 12:16 AM
03/07/06 12:16 AM
Chuck
You dont want that manifold.
Its not like the street hemi intake. Its based on an old marine hemi intake.
The carb spacing is farther apart so the factory aircleaners wont work.
Also, its an open planum intake but its a very poor design...similar to a vanke ported intake but with worse fuel distribution problems.
A&A transmission has an exact repro of the street hemi intake available but its spendy at around 1k.
If you dont mind the larger carb spacing then get a Stage V dual quad hemi intake like mine. It is just 1/2" taller over the street hemi piece and its a real single plane with killer design and performance. Its basically a short tunnel ram. Tests have showed serious HP improvements over a stock street hemi intake!...and its even cheaper than the MP intake you are considering....
Dom, THANKS for the input! I'll go on the "hunt" for a STAGE V, in the Am. I'll call Tim, at FHO, and see if he has one.. I always have had FIRST CLASS service on the previous purchases, so I'll just go back for some more!
[Re: Wagonmaster]
#23590
03/07/06 12:44 AM
03/07/06 12:44 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, Scott, you seem to have a handle on the Hemi manifolds, which one do I have - as in, is it truly an original - with part # 2780544?
Are you asking if it's a reproduction or not? If so there are none being sold yet so yes, #2780544 would be an original Street hemi dual 4 intake.
If you have a good pic of the front area I could probably tell you what vintage it is.
[Re: Rug_Trucker]
#23601
03/24/06 08:33 AM
03/24/06 08:33 AM
What? No Airgap for the 426?
Yes, there is. You were looking in the wrong place. It's under the ft wheels....
