Re: 275/35/18's on a Dart
[Re: Kern Dog]
#2358398
08/23/17 12:35 AM
08/23/17 12:35 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Good to know. If anything, I could show Summit or whoever the price and ask them to price match. I like blacks, but I'm just wondering how an all black wheel would look on my car. My guess is that the Dr Diff hubs are the correct size for Mopars, 2.81". A guy on FABO measured it for me. The Dr Diff bbp axles measure 2.795" (~71mm). The stock bbp axles measure 2.825" (~72mm). So, I should be good with Enkei's if I choose to go with them.
[Re: MuuMuu101]
#2364125
09/02/17 04:08 PM
09/02/17 04:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure how you squeezed 275's in the back of a stock 72 Swinger. I could just get 245's in, rolled fender lip, stock spring location. Had maybe 3/4" clearance ins'de and out.
That would just barely rub the leafs on hard turns.
Dr Diff says 1/2" more, which is maybe 13 mm. I guess if I was running 35 profiles instead of 60's and left 1/4" inside and out for clearance it could be done. Is you fender lip rolled or cut?
[Re: MuuMuu101]
#2364152
09/02/17 05:20 PM
09/02/17 05:20 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I had 275s on n the back of my 69 Valiant with the offset Shackel kit ... so they should fit a 72 Dart as well. JRC are you driving this beast around our fine Winnipeg streets yet?
A new iron curtain drawn across the 49th parallel
[Re: MuuMuu101]
#2364251
09/02/17 09:56 PM
09/02/17 09:56 PM
Supercuda
About to go away
About to go away
up yours
Sounds pretty tight, but the low profiles help. I was running a 3/4" rear sway bar as well, but the taller sidewalls let the tire flex enough to rub.
This wasn't a dedicated track car and I really do not like the feeling of a low profile tire on the street.
[Re: MuuMuu101]
#2364977
09/04/17 01:57 AM
09/04/17 01:57 AM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
That sounds comforting to know. It might be awhile before I can buy new wheels and tires. I just bought a new car. What did ya get????
[Re: Kern Dog]
#2365609
09/05/17 02:15 AM
09/05/17 02:15 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I can imagine Samy in a pink Fiat 500... A 2018 Subaru WRX to replace my Scion.
[Re: NV69B7RR]
#2366181
09/06/17 01:08 AM
09/06/17 01:08 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Really? No witty comment? Nah, it's blue and pretty cool. Very cool Sami. You going to autocross it? AWD can be a lot of fun!
Probably not, or at least anything competitively, unless my Dart is down. I've driven it about 300 miles since Thursday and it's pretty fun and the ride quality is 1000x's better than my Scion. I love how you can just throttle through the corners. Plus, this is my first turbo car so that's always fun to deal with. I'm going to try to baby this car as much as possible for a daily driver unlike my Scion. Besides that, the plan is to pick up the Dart on Friday. We'll see how finances go, but maybe I'll bite on wheels and tires early. I want to do quite a bit of measuring first to see what wheels will work. Ignore the Chevy Spark in the background.
[Re: MuuMuu101]
#2367775
09/09/17 05:36 AM
09/09/17 05:36 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
The car drives a lot better with 1.18" T-bars and the leaf springs moved in, but now I think I have transmission problems... I drove the car from the shop to my work and then to my gf's house (about 30 miles all on streets) and it seemed to do fine. Later on in the day, my gf and I went on a little joy ride and the Dart was great. My gf was ecstatic and loved it. It was really fun. Well, a couple hours later I had to take on the 30 mile journey home (mostly freeway). When I started the car, I kind of had a feeling there was a problem. I could sort of hear a little clunking noise from the car as it was idling and every time I pushed the clutch pedal it went away, but I wasn't sure. I put the car in reverse and backed out and as I shifted into 1st and was moving forward, it sounded like a mystery bolt came loose and clunked around for a second, dropped out of the car, then the car stopped and shut off. Keep in mind, the car was still a little cold (135-150F water temp) and has shut off on me when trying to move the car in 1st if it's not too warm (I rushed the warm up a little as I was trying to get home as it was late). I immediately started the car back up again and the noise was gone. I didn't want to scare my gf, so I drove away, planning on pulling over in a nearby neighborhood in case something happened as I didn't want her to worry (I know, not the smartest idea). Well, as I was driving, the car felt fine, until I got on the freeway. It could just be me since I haven't driven the car in 2 months, but it felt like the car was fighting itself to stay at speed (70-80 mph). My frame of reference could be out of wack because I just got a new daily driver last week and have been driving that a lot. But I also noticed that when I hit the exhaust drone RPM band and tried cruising at that speed that the vibration was a lot more than usual, but would smooth out significantly after I raised the engine speed outside of drone RPM. Lastly, what I thought was kind of weird, and I don't remember it doing this before, was that sometimes when I'd try to accelerate to pass a car (let's just say I'm at 2500 RPM in 5th gear) the RPM would rise to about 3000 (still in 5th) for a second or two, but the car would stay at the same speed, then the RPM would drop to about 2700 RPM and it would increase speed by a small amount. This also did sometimes occur when shifting from 5th to 6th and vice versa. It may have done it before, but who knows, my memory could be off. Anyways, I ended up getting home safe, but now I'm all freaked out that I have a transmission problem and I'm tired of spending money on this car. I swear this car hates me. I'm pretty frustrated with it at this point and if this ends up being something big, I'm parking the car until next June (when I finish my masters) because I don't have the time, patience, or money anymore to work on it. But who knows, this could all just be me and my tiredness.
[Re: Kern Dog]
#2368251
09/10/17 12:37 PM
09/10/17 12:37 PM
NV69B7RR
Reno, Nevada
[ I could sort of hear a little clunking noise from the car as it was idling and every time I pushed the clutch pedal it went away, but I wasn't sure. I put the car in reverse and backed out and as I shifted into 1st and was moving forward, it sounded like a mystery bolt came loose and clunked around for a second, dropped out of the car,
quote=Frankenduster]A bolt holding the pressure plate could have rattled loose and fallen out. This will result in UNeven pressure to hold the clutch, especially under power. [/quote]
I'm going to guess that he's right. Put the car up on jackstands, pull the inspection cover off and check to make sure all of the bolts holding the clutch/pressure plate to the flywheel are still there by rotating the engine over.
Is there anyway to go look for that mystery bolt? Finding it may answer the question of where it came from rather quickly.
[Re: NV69B7RR]
#2368293
09/10/17 01:36 PM
09/10/17 01:36 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
quote=Frankenduster]A bolt holding the pressure plate could have rattled loose and fallen out. This will result in UNeven pressure to hold the clutch, especially under power. I'm going to guess that he's right. Put the car up on jackstands, pull the inspection cover off and check to make sure all of the bolts holding the clutch/pressure plate to the flywheel are still there by rotating the engine over. Is there anyway to go look for that mystery bolt? Finding it may answer the question of where it came from rather quickly. Where's the inspection cover? The bellhousing doesn't really have any slots to inspect the pressure plate. I'd have to go to my gf's house and look around the street to find the bolt.
