66 Fury gas tank #2357551
08/21/17 01:20 PM
08/21/17 01:20 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Have a friend with a rigged-up fuel cell in his '66 Fury that is likely leaking from some connection point. (I have not been under the car myself yet, not certain what the issue is, going by what he described to me) Regardless, It's not a race car so he'd like to replace the cell with an OE type tank and lines.
Unfortunately, we are having a hard time locating a reproduction tank and good used ones don't seem to come up at all.
It's my understanding that 65 AND 66 Fury gas tanks are each one-year-only parts. Is this correct?
Can someone point me in thee right direction for getting a tank in this thing without spending a fortune on a custom one?
Thanks,
- Greg
'71 Duster
'17 Ram 1500
Re: 66 Fury gas tank [Re: RMCHRGR] #2357707
08/21/17 05:38 PM
08/21/17 05:38 PM
KY
65pacecar Offline
65pacecar  Offline
KY
NO repops for the tanks yet (65 or 66) Basically the same tank, 65 is side fill, 66 is rear. Vans is going to reproduce the 65 version and is due out next Spring, I would expect them to make a rear or side fill version of that tank. With some mods, a rear fill B-Body tank can work.
Re: 66 Fury gas tank [Re: RMCHRGR] #2357721
08/21/17 06:05 PM
08/21/17 06:05 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Some guys on the FCBO board have used the 67 C-body tank from Spectra successfully on 65 and 66 rear fill cars.
Some have had to trim the lip on the tank a little and others with the same car just bolt in. shruggy
Your mileage may vary.
Kevin
Re: 66 Fury gas tank [Re: RMCHRGR] #2358013
08/22/17 09:07 AM
08/22/17 09:07 AM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Thanks for the replies, sounds like there are options at least.
If you use one of these alternate tanks, which tank straps would you use?
I also imagine finding a filler neck for this thing will be just as tough.
'71 Duster
'17 Ram 1500
