74'a-body discs conversion on 72' Charger,what hoses to use? #2356052
08/18/17 02:09 PM
08/18/17 02:09 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Putting 1974 a/e-body disc bakes on my 1972 Charger and trying to get the correct length brake hoses for it. A-body ones I thought would work are too short and not sure which ones to use. Tring to get my front suspension all on this weekend since my Firm Feel steering box just showed up. What hoses can I use from which model of car?
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356055
08/18/17 02:13 PM
08/18/17 02:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seeing that the 71-2 B body is very similar to the 70-74 E body in many respects, you should be able to use 71-2 B body lines, or 70-74 E body lines, the calipers are the same, location is the same, all the front end pieces are interchangeable
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: DAYCLONA] #2356059
08/18/17 02:18 PM
08/18/17 02:18 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
Calipers are different between the A & E body line of cars.
73 - 76 A Bodies use "SLIDER" type of calipers.
70-74 E Body, 70-72 B body cars use "PIN TYPE" calipers.
Gotta know what type caliper the op is using before telling him what type hose to buy.
Then also gotta know if mounting the calipers towards the front of the car, or the rear.
Lot's to find out.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356137
08/18/17 04:54 PM
08/18/17 04:54 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
1974 a-body's use slider caliper and they are in the stock location.
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356177
08/18/17 06:36 PM
08/18/17 06:36 PM
Others have been using the rubber flex hoses, from the Aspen & Volare, line of cars.
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356187
08/18/17 07:01 PM
08/18/17 07:01 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
ok, will check that out, hope it works! thanks
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356232
08/18/17 09:10 PM
08/18/17 09:10 PM
^^ agreed, check out a hose for a 78 volare at your parts house. cut off half of the metal bracket that is in the middle of the length of the hose for aesthetics as it ain't needed for your app.
Re: 74'a-body discs conversion on 72' Charger,what hoses to use? [Re: migsBIG] #2356242
08/18/17 09:29 PM
08/18/17 09:29 PM
AndyF Offline
AndyF  Offline
I think Doctor Diff sells the correct hoses for the various brake swaps.
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356285
08/18/17 11:00 PM
08/18/17 11:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use 72 Charger brakes on my Savoy with forward mount pin type calipers and the Wagner E-body hoses worked perfectly.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: fourgearsavoy] #2356294
08/18/17 11:18 PM
08/18/17 11:18 PM
Gus beer
The op is using SLIDER type calipers, which aren't original to his Charger.
Re: 74' discs conversion on 72' Charger, what hoses to use? [Re: migsBIG] #2356350
08/19/17 01:07 AM
08/19/17 01:07 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you are using '74 slider calipers, mount them toward the front and use '73-'76 A-body (disc) hoses.
