Page 11 of 12 1 2 9 10 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: ksj] #2166160
10/01/16 10:34 PM
10/01/16 10:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Awesome! We did the Friday night test and tune and went to the swap meet up there last weekend. You guys have an AWESOME track to play at!
Re: 420cid build with a new Ritter Aluminum Block [Re: MoparBilly] #2166331
10/02/16 10:03 AM
10/02/16 10:03 AM
moparx Offline
moparx  Offline
Originally Posted By MoparBilly
Moparx,
I borrowed the photos from Bob Brehm's facebook page. Bob is the best amateur automotive event photographer in the mid-west!
Bob was a school friend of Doug, KSJ's brother, and he told me at Drag Week that KSJ's only redeeming quality was that he introduced Bob to 69 lawndart!
I have to agree KSJ has an innate knack of introducing cool people to other cool people!! While he is definitely not in that club, he serves as a kind of Social honey bee.
well, regardless if you borrowed those pics, i'm glad you did billy. i have tried a couple of different ways to attach dog dish caps to different wheels with varying results always using the original "snap on" method of retention. my old, cloudy mind never gave it a thought to use a retention screw method, and i just looked at a cap laying around and concluded a nice flat head or button head 8 or 10-32 stainless screw would work perfect for what needs to be done and not be easily observed. so in the end, all you guys helped my old mind with a good kick start. up and i am very appreciative of all you guys ! thanks again billy for getting this ball rolling and allowing me to obtain the info i was seeking ! bow
beer
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2180146
10/22/16 03:08 AM
10/22/16 03:08 AM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
Last update, Went back to the track this evening the car went 10.285 @ 134.83 MPH and 10.224 @ 135.35 MPH, still on the conservative side leaving RPM and shifting. Motor seams happy, clean oil and good pressure.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2180148
10/22/16 03:24 AM
10/22/16 03:24 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Good to hear.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2180260
10/22/16 12:22 PM
10/22/16 12:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"last update"??? hoping that just poor wording, I prefer "latest update" smile that ride is just sooo cool!
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2180611
10/23/16 12:17 AM
10/23/16 12:17 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good to see some more laps on this.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356012
08/18/17 01:01 PM
08/18/17 01:01 PM
Kansas, Topeka
Kansas, Topeka
Latest up date, I pulled the motor out of the car it has about4300 miles on it with no problems. Right now it is sitting on a Dyno and we have made 11 pulls, the numbers are not that great but we will keep working on it. the oil pressure is great and it is giving us no sign of problems.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356020
08/18/17 01:11 PM
08/18/17 01:11 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Great news
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356022
08/18/17 01:17 PM
08/18/17 01:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sounds like you're headed in the right direction.
Keep us posted drive
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356068
08/18/17 02:59 PM
08/18/17 02:59 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
There is a block on racing junk right now 4100.00 new with some machine work done
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356069
08/18/17 02:59 PM
08/18/17 02:59 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2356071
08/18/17 03:03 PM
08/18/17 03:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That is not in the owners possession apparently still at Ritters....
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2427357
01/01/18 07:56 PM
01/01/18 07:56 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Hows it going with this project lawndart??
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2428374
01/03/18 05:05 PM
01/03/18 05:05 PM
Kansas, Topeka
Kansas, Topeka
I pulled it last Friday to look it over. It looks Ok, its not great and it not bad, on three of the rod bearing the coating looks like it flaked off on the top of the bearing. The main bearings look good, cam bearing are showing some wear but that's expected with the spring pressures and RPM I am running. Piston skirts looked good nothing to be worried about.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2428399
01/03/18 06:02 PM
01/03/18 06:02 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did you find any power with what you tried on the dyno?
Is it up to your expectations, or will you be looking for more when it goes back together?
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2428424
01/03/18 06:55 PM
01/03/18 06:55 PM
Kansas, Topeka
Kansas, Topeka
Yes I found a little more power on the dyno but not ready to put a hood scoop on the car. I have mixed feeling on my expectations on one hand it ran as good with this new aluminum Ritter block as it did with the R3 block before the come a part. But on the other hand I don't think the motor is running up to its potential. Yes I will be changing things when it goes back together.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2428536
01/03/18 10:29 PM
01/03/18 10:29 PM
Mopar
Jason B Offline
Jason B  Offline
Mopar
Great post man glad to see someone out here making it work... great job
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: 420cid build with a new Ritter Aluminum Block [Re: Jason B] #2428600
01/03/18 11:41 PM
01/03/18 11:41 PM
Kansas, Topeka
Kansas, Topeka
Thank you sir
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2429785
01/06/18 04:06 AM
01/06/18 04:06 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
What a nice build!
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2429852
01/06/18 12:05 PM
01/06/18 12:05 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Mike,
Have you made a decision on HR Drag Week 2018 yet?
It would be good to see you back.
Thanks for sharing what you learn with us.
Bill
