Cleaning Block Deck After Steel Shim Head Gaskets #2355122
08/16/17 10:21 PM
08/16/17 10:21 PM
Fort Worth, TX
Clair_Davis Offline OP
Fort Worth, TX
I've got a '77 440 that I'm going over and will be replacing the steel shim head gaskets with an NOS set I've had for years. I have scraped the deck surface with a razor, but still have some sort of imprint on the deck:
77_440_Gasket_Print by clair_davis, on Flickr
The imprint almost seems like it's part of the tin plating or something from the shim... it doesn't seem to come off with a razor, but I can feel it if I scrape it with my fingernail. What do I have to do to get this stuff off, or do I need to worry about it? I would guess it's a couple thousandths thick if I can feel it, and with an 0.020" gasket, that might be too much to leave behind.
Thanks,
Clair
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355205
08/17/17 12:22 AM
08/17/17 12:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Lacquer thinner usually get that off but really, its not enough to worry about.
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355270
08/17/17 03:15 AM
08/17/17 03:15 AM
The OEM 400 and 440 head gaskets are .017 thick, the smaller bore 426.383,413 and 361 C.I. motor head gaskets where .022 scope
As far as feeling and removing the paint residue from the old head gaskets use some laquer thinner and a small stainless brush to remove that scope
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355322
08/17/17 10:02 AM
08/17/17 10:02 AM
Fort Worth, TX
Fort Worth, TX
Thanks, guys!
I tried some lacquer thinner and some acetone last night with no luck. On another forum, I saw where a guy was basically floating a fine flat file over the deck surface that he was wetting with WD-40, and this seems to be doing the trick. Cleaning up the rust/corrosion around the water passages, too - not removing any real metal, but leaving a nice bright surface now.
And good info on the gasket thickness for the 400/440 - that should bump my compression up from 7.98 to 8.01:1!
Thanks again,
Clair
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355423
08/17/17 01:03 PM
08/17/17 01:03 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By Clair_Davis
...On another forum, I saw where a guy was basically floating a fine flat file over the deck surface that he was wetting with WD-40, and this seems to be doing the trick....
Don't get carried away with the file. Unless you are running an MLS gasket there needs to be some "teeth' on the deck surface for the gasket to bite into. Now I know Fel-Pro says their MLS gaskets can seal on a typical deck finish. Maybe so, I have no experience with these.
Fel-Pro MLS
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355469
08/17/17 02:32 PM
08/17/17 02:32 PM
Fort Worth, TX
Fort Worth, TX
I'm definitely not trying to remove anything beyond the printed residue on the deck. I'm doing this with the deck perpendicular to the ground and only applying enough pressure to hold the file flat on the deck face. There are still clearly visible surface marks from the original machining - I'll get a pic this evening after work.
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355793
08/17/17 11:42 PM
08/17/17 11:42 PM
I think your going way out of your way to make sure it is perfect when your done, that is not really needed tsk
Think of all the Mopar vechicles, both muscle and standard Mopar cars that dealer mechanics work on that got paid book time only that slammed a lot of head gaskets on without going through the effort your doing work
My message is your good, put it together and go drive it up twocents
EDITED: Make sure and spray 2 to 3 light coats of either silver or aluminum paint onto the steel head gaskets(coat both sides completely) before using them, make sure and allow each coat to dry before spraying the next one up
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2355829
08/18/17 01:03 AM
08/18/17 01:03 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I've always used a wire wheel in a drill to clean the deck and head surfaces. Works fine and you need very little pressure to do the trick. Wipe it down with some laquer thinner and slap it together.
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Cab_Burge] #2355970
08/18/17 11:43 AM
08/18/17 11:43 AM
Guitar Jones Offline
I'm a dealer flat rate tech. I do a lot of engine work and all my surfaces are clean, clean and clean. Did I mention clean? I use a scotchbrite pad after the razor blade. And not on a power tool. Since replacement gaskets and seals are not able to be parts warrantied for defects (you should have caught that before you installed it) that is a job I don't want to do a second time for free. It's way worth it to spend a little extra time and do right the first time then to have to do it right the second time for free.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2356076
08/18/17 03:05 PM
08/18/17 03:05 PM
Fort Worth, TX
Fort Worth, TX
I figure if I can spend an extra 30-45 minutes cleaning it up, it's worth not jacking with it again. I would probably have been more comfortable with less prep if I wasn't using a steel gasket, but I want to keep every bit of compression I can in this engine. I was also not comfortable using a scotchbrite pad from a loose abrasives standpoint. I need to research that option more, since it seems pretty common practice. There must be some job-specific parts that I just don't know about, but everything I have on hand is for bodywork and dumps abrasive material like crazy.
The file operation worked pretty well, I think. Shows how crappy the factory fly-cut was on the deck surface in the beginning, but the file got rid of the high spots of the print. Can still see the print, but it won't catch a nail now.
77_440_Gasket_File-01 by clair_davis, on Flickr
All of the rust around the water ports is smooth now, too.
77_440_Gasket_File-02 by clair_davis, on Flickr
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: elmor353] #2356297
08/18/17 11:25 PM
08/18/17 11:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
yup, this is what I've been doing for a number of decades.
Never had any issues.
I have mechanical Aptitude.
I can screw up anything.
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2356302
08/18/17 11:40 PM
08/18/17 11:40 PM
Fort Worth, TX
Fort Worth, TX
Awesome - I'll do that with the heads when I clean them up. Will be nice having a few different ways to skin that cat, and the heads don't have any critical places to hide stray wires, boogers, or crud like the cylinders do...
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: bboogieart] #2356305
08/18/17 11:48 PM
08/18/17 11:48 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
A little more but its all good.
Steel gaskets are all good!!!!
Have a great day
Iowan
"obsolete is neat"
Re: Cleaning Block Deck After Steel Shim Head Gaskets [Re: Clair_Davis] #2356361
08/19/17 01:33 AM
08/19/17 01:33 AM
A727Tflite Offline
A727Tflite  Offline
Google 3M Roloc - when we had issues with head gasket failures on the 2.0 and 2.4 SOHC and DOHC Mopar engines this was one of the approved methods to clean the head (aluminum) before installing the then new MLS gasket. The correct Roloc cleans but does not damage the parent material. Tape off the area around the deck before cleaning. Then lightly oil the bores when done and rotate the engine by hand. Any debris will now be at the top of the bore stuck on the oil film. Just clean it out of the bores and you are good.
