Shock Absorber Question? #2355638
08/17/17 08:14 PM
08/17/17 08:14 PM
BlueRacer69 Offline OP
Hey guys, anyone know if Shocks for a 1965-70 C-body will fit and work properly on a 1969 A-body? Or will they have to much travel to them.
Re: Shock Absorber Question? [Re: BlueRacer69] #2355659
08/17/17 08:45 PM
08/17/17 08:45 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
What is your set up?
If stock, the C body shocks would be to long.
I have mechanical Aptitude.
I can screw up anything.
Re: Shock Absorber Question? [Re: bboogieart] #2355668
08/17/17 08:57 PM
08/17/17 08:57 PM
Yes it's stock. I was thinking they mite have to much travel. Thanks for the advice.
Re: Shock Absorber Question? [Re: BlueRacer69] #2355861
08/18/17 02:40 AM
08/18/17 02:40 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Aren't longer shocks required if using SS springs?
Re: Shock Absorber Question? [Re: wkroncke17] #2355865
08/18/17 02:59 AM
08/18/17 02:59 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Yes and some guys use the C body shocks on the cheap.
Re: Shock Absorber Question? [Re: BlueRacer69] #2355872
08/18/17 03:18 AM
08/18/17 03:18 AM
You might measure how much distance there is from C to C between the top/bottom bolts. You want the shock selection to have a certain amt of compression at rest (not my area, just sayin).
Re: Shock Absorber Question? [Re: BlueRacer69] #2356143
08/18/17 05:01 PM
08/18/17 05:01 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi blue, if you use a c-body shock like Monroe 32073 ,it has a different upper bushing with a sleeve in it that is different than the a-body style, like Monroe 31131, that has the same bushing top and bottom. ronnie
Re: Shock Absorber Question? [Re: wkroncke17] #2356293
08/18/17 11:14 PM
08/18/17 11:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
O.P. never mentioned SS springs , he said it was stock. shruggy
Re: Shock Absorber Question? [Re: bboogieart] #2356349
08/19/17 01:06 AM
08/19/17 01:06 AM
Yes it is stock for right now. But what if (say down the road) I put a new set of springs under it from Springs & Things with a +2 lift. Won't it require longer shocks?
Re: Shock Absorber Question? [Re: BlueRacer69] #2356369
08/19/17 01:49 AM
08/19/17 01:49 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Ah... rear shocks.
Might need longer shocks with a +2" lift, but you really ought to measure when you get the springs installed. Shocks that are too short aren't as big a problem as shocks that are too long - if they extend all the way, they pick up the axle. If too long, they bottom out. You can get some specs on the OEM shocks and see how they compare to other models or PN's in a shock catalog.
When I was looking years ago, the info I got on the 65-72 C-body shocks was this:
Extended Length = 22.5" (average of a few sources)
Compressed Length = 13.5" (average of a few sources)
FWIW, A-body rear shocks are actually LONGER than C-body rear shocks by about an inch compressed and half an inch extended.
Re: Shock Absorber Question? [Re: BlueRacer69] #2356402
08/19/17 03:54 AM
08/19/17 03:54 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Unbolt the bottom of your current shock set-up and let the rear-end hang free. Then measure from the shock plate stud to the top shock bolt to see how much length you can handle without shock bind.
twocents
Re: Shock Absorber Question? [Re: BlueRacer69] #2356443
08/19/17 09:29 AM
08/19/17 09:29 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What if he puts in a 4 link, that's need different shocks.
What if he put in a Jag rear end, that'd require different shocks.
We can what if all day. None of which matters.
Don't be the exception.
Re: Shock Absorber Question? [Re: Supercuda] #2356501
08/19/17 12:18 PM
08/19/17 12:18 PM
I would get loaded & extended C to C distances for a baseline to work with. Then add/subtract as needed.
Re: Shock Absorber Question? [Re: RapidRobert] #2356531
08/19/17 01:04 PM
08/19/17 01:04 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
THIS! green
Re: Shock Absorber Question? [Re: BlueRacer69] #2356540
08/19/17 01:21 PM
08/19/17 01:21 PM
Thanks everybody.You guys are a world of info and help.I just love this site.
