take the wire off of the gauge as it might be grounded somewhere, otherwise yes it sure sounds like the gauge went belly up.
Yep I think it did as well. The water temp gauge has the same ground as all the rest of my gauges and they all work fine and have for years and year.
I put a multimeter on the wire leading to the sensor and it had voltage to it with the ignition in the ON position. I grounded that wire just to see what it would do at the gauge and it did absolutely nothing. LOL!!!
I will get a new gauge. Thanks!
