Re: Shock Absorber Question?
[Re: BlueRacer69]
#2355659
08/17/17 08:45 PM
08/17/17 08:45 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
What is your set up? If stock, the C body shocks would be to long.
I have mechanical Aptitude. I can screw up anything.
[Re: wkroncke17]
#2355865
08/18/17 02:59 AM
08/18/17 02:59 AM
Posts: 792 Earth
Rob C
Earth
Aren't longer shocks required if using SS springs? Yes and some guys use the C body shocks on the cheap.
[Re: BlueRacer69]
#2355872
08/18/17 03:18 AM
08/18/17 03:18 AM
RapidRobert
You might measure how much distance there is from C to C between the top/bottom bolts. You want the shock selection to have a certain amt of compression at rest (not my area, just sayin).
[Re: wkroncke17]
#2356293
08/18/17 11:14 PM
08/18/17 11:14 PM
bboogieart
Lost and Spaced
Aren't longer shocks required if using SS springs? O.P. never mentioned SS springs , he said it was stock.
[Re: bboogieart]
#2356349
08/19/17 01:06 AM
08/19/17 01:06 AM
Posts: 723 Michigan
BlueRacer69
Aren't longer shocks required if using SS springs? O.P. never mentioned SS springs , he said it was stock. Yes it is stock for right now. But what if (say down the road) I put a new set of springs under it from Springs & Things with a +2 lift. Won't it require longer shocks?
[Re: BlueRacer69]
#2356443
08/19/17 09:29 AM
08/19/17 09:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Aren't longer shocks required if using SS springs? O.P. never mentioned SS springs , he said it was stock. Yes it is stock for right now. But what if (say down the road) I put a new set of springs under it from Springs & Things with a +2 lift. Won't it require longer shocks? What if he puts in a 4 link, that's need different shocks. What if he put in a Jag rear end, that'd require different shocks. We can what if all day. None of which matters.
[Re: Supercuda]
#2356501
08/19/17 12:18 PM
08/19/17 12:18 PM
RapidRobert
I would get loaded & extended C to C distances for a baseline to work with. Then add/subtract as needed.
