Blackout paint #2355451
08/17/17 02:00 PM
08/17/17 02:00 PM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
Is the blackout paint flat or satin/semi gloss?
car is 71 challenger
Re: Blackout paint [Re: 440farmer] #2355510
08/17/17 03:37 PM
08/17/17 03:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I use SEM Trim Black for the blackout. Don't know if you would consider that semi-gloss or satin.
Re: Blackout paint [Re: 440farmer] #2355511
08/17/17 03:40 PM
08/17/17 03:40 PM
Sharpsburg Maryland
Sharpsburg Maryland
I do have some SEM e coat black that's not the same is it??
I'll probably use the Krylon satin black and let her rip!
Re: Blackout paint [Re: 440farmer] #2355847
08/18/17 01:53 AM
08/18/17 01:53 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
What do you mean blackout paint?
Sometimes people mean the area around the headlamps and radiator support - if so PPG DP90 works great
If you mean the black paint that goes on body above the taillamps it's Organisol
Re: Blackout paint [Re: 440farmer] #2355892
08/18/17 04:38 AM
08/18/17 04:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you're asking about blackout behind the grill and SEM there are three different gloss types of SEM Trim paint so you want the flattest black type. I've tried and have every gloss type SEM Trim (black) paint and really found that for the best (IMO sorry) rattle can look/paint that Krylon ULTRA-FLAT black to be the best for grille blackout. Again just my experience and opinion...and you know what they say about opin..... wink
MikeR
Re: Blackout paint [Re: A12] #2355898
08/18/17 05:02 AM
08/18/17 05:02 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is the Ultra-Flat on my Sunfire Yellow '69 GTX
Re: Blackout paint [Re: 440farmer] #2356084
08/18/17 03:17 PM
08/18/17 03:17 PM
Sharpsburg Maryland
Sharpsburg Maryland
Thanks everyone
Yeah it is behind the grill
I do have that flat black
Re: Blackout paint [Re: 440farmer] #2358184
08/22/17 05:33 PM
08/22/17 05:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Pretty sure I just used whatever flat black rattle can I had. Lying on my back, pointing up trying to get similar coverage as factory did (although I think I got "more" on than factory) . . . .
