Bolt on hub/bearing assembly
#2354985
08/16/17 05:55 PM
08/16/17 05:55 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Is anyone making a bolt on hub assembly yet for the old stuff, or is the answer still 'take an original rotor and turn it down in a lathe to make one'?
Looking for a hub assembly that fits onto the spindle and is held on with the original castle nut, that allows you to use slip on rotors.
**Photobucket sucks**
Re: Bolt on hub/bearing assembly
[Re: BigBlockMopar]
#2355117
08/16/17 10:18 PM
08/16/17 10:18 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Any old front wheel 'brake drum' has these hubs 'incorporated' and would be easy to seperate and source to come by. Drumbrake-hubs might even have a better (narrower) track width too. That would be the smaller bearing set-up, correct? Same option is not available in the big bearing?
[Re: GoodysGotaCuda]
#2355173
08/16/17 11:43 PM
08/16/17 11:43 PM
70Cuda383
Marysville, O-H-I-O
My Wilwood hubs use slip on rotors. Factory e-body drum spindles. Do you have pics or part numbers? I saw some wilwoods, but they looked like the kind of hub that uses a 2 piece rotor, and the friction surface bolts to the back side of the hub. I'd like to find hubs that use true slip on rotors so I can use any rotor with the right bolt pattern.
[Re: 70Cuda383]
#2355342
08/17/17 10:36 AM
08/17/17 10:36 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Wilwood hubs use slip on rotors. Factory e-body drum spindles. Do you have pics or part numbers? I saw some wilwoods, but they looked like the kind of hub that uses a 2 piece rotor, and the friction surface bolts to the back side of the hub. I'd like to find hubs that use true slip on rotors so I can use any rotor with the right bolt pattern. I don't have any disassembled photos but their instructions for the ebody kit has good exploded diagrams. My rotors are multi pattern slip on.
[Re: 70Cuda383]
#2355361
08/17/17 10:56 AM
08/17/17 10:56 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Cass - Dr Diff. Aluminum.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: 70Cuda383]
#2356133
08/18/17 04:40 PM
08/18/17 04:40 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Dr. Diff offers some good setups... he probably has exactly what you're looking for. I've seen a couple on local cars (HSAX/HPDE)... good quality, etc.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: jcc]
#2356299
08/18/17 11:36 PM
08/18/17 11:36 PM
Posts: 259 n.c.
geo.
n.c.
Any old front wheel 'brake drum' has these hubs 'incorporated' and would be easy to seperate and source to come by. Drumbrake-hubs might even have a better (narrower) track width too. That would be the smaller bearing set-up, correct? Same option is not available in the big bearing? Only one I've heard of is '73- A body with drums, think it's small bolt pattern
[Re: 70Cuda383]
#2356367
08/19/17 01:43 AM
08/19/17 01:43 AM
Posts: 30,992 Oregon
AndyF
Looking for a hub assembly that fits onto the spindle and is held on with the original castle nut, that allows you to use slip on rotors. You are talking about two different things. You can buy aluminum hubs from Baer or Wilwood that use the factory style bearings and seals. I wouldn't really call that a bolt on hub assembly though. A hub assembly is what most of the new cars have where the bearings are all sealed in a hub assembly and the whole thing is held on with a big nut and a lot of torque. I designed a setup like that for Mopar vehicles but I didn't have the money to tool it up. The design is fairly simple and it would provide a bunch of advantages but it would cost a ton of money to produce.
[Re: AndyF]
#2356425
08/19/17 07:36 AM
08/19/17 07:36 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Andy, did you look at having Coleman build the spindles for that type of hub/bearing?
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: 70Cuda383]
#2356913
08/20/17 01:37 AM
08/20/17 01:37 AM
70Cuda383
Marysville, O-H-I-O
Sealed bearings would be cool, but I'd be ok with a hub assembly that uses hand packed wheel bearings, primary goal being a hub that I can slip any 5-lug rotor onto, allowing me to fabricate my own brake kit. I know there's some good kits out there but most are using wilwood or Baer calipers. I prefer to use Brembos found on OEM set ups for ease if replavement parts, and the reliability of an all weather caliper complete with dust boots vs the 'resto-mod' stuff that lacks boots.
[Re: 70Cuda383]
#2356979
08/20/17 07:40 AM
08/20/17 07:40 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
The different offsets in the hubs is a nice thing the a-body crowd would love. Pretty much every discbrake conversion makes the trackwidth wider on these, while tire/fender clearance is already too close to run a decent width tire and a nice stance. Too bad they're such cheap-a folks usually
[Re: BigBlockMopar]
#2357019
08/20/17 10:56 AM
08/20/17 10:56 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
The different offsets in the hubs is a nice thing the a-body crowd would love. Pretty much every discbrake conversion makes the trackwidth wider on these, while tire/fender clearance is already too close to run a decent width tire and a nice stance. Too bad they're such cheap-a folks usually Really? This is an 18x9 +35mm wheel with a 275-35-18 on it with the Dr Diff Cobra brakes, nothing really custom here. Ideal would have been 2mm further in but it doesn't hit at all so I'm not concerned. You're just not going to be running a zero offset wheel. Unless there's something special about Valiant/Duster fenders I don't know about, I don't see why this would be an issue on any 67-76 A-body. I also have the B-body axle in the back to match.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2357046
08/20/17 12:02 PM
08/20/17 12:02 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
The different offsets in the hubs is a nice thing the a-body crowd would love. Pretty much every discbrake conversion makes the trackwidth wider on these, while tire/fender clearance is already too close to run a decent width tire and a nice stance. Too bad they're such cheap-a folks usually Really? This is an 18x9 +35mm wheel with a 275-35-18 on it with the Dr Diff Cobra brakes, nothing really custom here. Ideal would have been 2mm further in but it doesn't hit at all so I'm not concerned. You're just not going to be running a zero offset wheel. Unless there's something special about Valiant/Duster fenders I don't know about, I don't see why this would be an issue on any 67-76 A-body. I also have the B-body axle in the back to match. Which year(s) B-body axle are you running; 65-67 or 68-70?
