5.7 build plans #2353329
08/13/17 07:42 PM
08/13/17 07:42 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
Starting to gather stuff for a low budget 5.7 build
How much power will an early 5.7 block hold? I've been hearing 1200whp with a short fill. I'd like to hear of other people with successful high HP 5.7 based builds.
Also, will the bottom of the bores need clearanced with a H beam rod?
Also, as far as coils are the 09+ coils different connector wise then the early ones?
Re: 5.7 build plans [Re: 1980volare] #2353361
08/13/17 09:47 PM
08/13/17 09:47 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I have H beam rods with a 4.05 stroke crank and have plenty of clearance stock.. as for the coils I believe 06 was when they were changed.. I believe 06+ will be the same connector and 05 and down will be a different connector..
Re: 5.7 build plans [Re: 1980volare] #2353726
08/14/17 05:04 PM
08/14/17 05:04 PM
Dayton, OH
Dayton, OH
Thank you.. according to the parts stores the coils are the same for a 07 and a 2014.
I will be using a 3.795 stroke so I should be good.
Re: 5.7 build plans [Re: 1980volare] #2354646
08/16/17 03:26 AM
08/16/17 03:26 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I am using a nice 2003 5.7 Hemi block. Supposed to have somewhat thicker cylinder walls. I hear 1,000hp is doable in stock form. Koffle's Place in Huron, Ohio did all my machine work...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 5.7 build plans [Re: 1980volare] #2354698
08/16/17 09:42 AM
08/16/17 09:42 AM
Dayton, OH
Dayton, OH
Sweet, I've got a little filler left from my SB two years ago so I'll probably do a small fill, just in case.
Really worried about lifting the stock heads more then anything at his point.
Re: 5.7 build plans [Re: 1980volare] #2354888
08/16/17 03:10 PM
08/16/17 03:10 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
There has been some serious boost put in to the G3's
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
