No more Hughes Whiplash hydraulic roller cams #2354689
08/16/17 09:09 AM
08/16/17 09:09 AM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
They are no longer listed in the online catalog.
Re: No more Hughes Whiplash hydraulic roller cams [Re: Eggman] #2354821
08/16/17 01:16 PM
08/16/17 01:16 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Specs on mine is 222/228 @ .050 107 LSA with +3 ground into the cam. lift is .544/.544 with Magnum 1.6 ratio rockers.
I'm sure if you called them and asked for a 'custom grind' they would run it for you.
**Photobucket sucks**
