Re: VICTOR MAX WEDGE HEADS!
[Re: BradH]
#2484865
04/18/18 10:51 PM
04/18/18 10:51 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I would be interested in flow numbers you are getting? My head porter is working on a set for me currently when I read Hughes figures he didn't believe them. He doesn't believe there is 400 cfm in the head without going through in places. Doesn't like the rocker oil casting in the port, cross section is too small at the turn .Think he is at around 360 cfm at .700 Maybe these will give him some ideas: http://speierracingheads.com/BBMv3.3.htmhttps://www.buyracingparts.com/cnc-porte...roller-cam.html Looking at those prices and claimed results make the Trick Flow offerings look better all the time.
[Re: Mal440]
#2485024
04/19/18 11:35 AM
04/19/18 11:35 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Think he is at around 360 cfm at .700 Button them up and call it good.
[Re: fast68plymouth]
#2485068
04/19/18 01:02 PM
04/19/18 01:02 PM
Posts: 1,048 The Great White North
RAMM
Think he is at around 360 cfm at .700 Button them up and call it good. Agree ^^^^^^^^^^^^^^^^^ Best I have ever done is 372 cfm @ .700" and that was one port that I was really developing. 400 cfm is going to be a very large port either way. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: viperblue72]
#2485259
04/19/18 08:39 PM
04/19/18 08:39 PM
Posts: 16 Lynnwood WA
MikeStahl
Lynnwood WA
Here's What I got with port work from Jim Laroy and 2.25 valves These are Procomps CNC before in/ex............now in/ex .100..........72/62................77/61 .200.........151/122.............156/140 .300.........218/171.............222/188 .400.........264/209.............280/223 .500.........296/240.............332/254 .600.........325/261.............354/276 .700.........342/271.............363/288 .800.........351/287.............370/304
[Re: viperblue72]
#2485450
04/20/18 05:13 AM
04/20/18 05:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I had the Hughes CNC ported Victor MW heads flowed. and posted the flow sheet here: https://board.moparts.org/ubbthreads/ubbt...tml#Post1946988They flowed 377 @ 0.800" (360 @ 0.700") on a 4.310 bore fixture and no radius port entry. I think on a larger bore fixture and with a radius plate the numbers would show higher? Best Machine also posted a flow sheet with 461.5 @ 0.700", but only 367.8 @ 0.800" That was on a 4.500" bore.
[Re: 451Mopar]
#2486020
04/21/18 11:56 AM
04/21/18 11:56 AM
BradH
They flowed 377 @ 0.800" (360 @ 0.700") on a 4.310 bore fixture and no radius port entry. If there was no radiused entry used, the numbers aren't valid. Yet, those tests look fairly consistent with other tests I've seen. Testing without a proper entry shape jacks up the results. Nobody I know who does this stuff ever tests without one.
