Correct '71 Master Cylinder cover? #2353352
08/13/17 09:11 PM
08/13/17 09:11 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
What's the correct cover for a '71 Demon disc/drum master cylinder? A pic would be awesome. Gold anodized?
Still looking for LM29H1B415501, '71 Demon 340
Re: Correct '71 Master Cylinder cover? [Re: PAULS_340] #2353359
08/13/17 09:41 PM
08/13/17 09:41 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
cad silver
Re: Correct '71 Master Cylinder cover? [Re: chrisf] #2354649
08/16/17 03:36 AM
08/16/17 03:36 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By chrisf
cad silver
I would check with MasterShake340 before going CAD silver
Re: Correct '71 Master Cylinder cover? [Re: Morty426] #2354735
08/16/17 11:22 AM
08/16/17 11:22 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
this...
Re: Correct '71 Master Cylinder cover? [Re: gygeneral] #2354745
08/16/17 11:30 AM
08/16/17 11:30 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By gygeneral
this...
Yes and you can see it's not CAD silver
Re: Correct '71 Master Cylinder cover? [Re: Morty426] #2355159
08/16/17 11:22 PM
08/16/17 11:22 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
i always tought it was gray phosphate like the black phosphate on nuts and bolts.
Re: Correct '71 Master Cylinder cover? [Re: gygeneral] #2355195
08/17/17 12:08 AM
08/17/17 12:08 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
That's a picture of a master cylinder I had, and I've seen that gray phosphate coating on both disc drum and drum drum NOS Mopar masters of the early 70s. I haven't seen what I believe to be the original master cylinder on a survivor car (they usually go bad over time and were replaced at some point even if most of the original car survived unmolested), but assume the ones originally installed were gray phosphate coated too.
