Mopar t post jacks #2352057
08/10/17 08:11 PM
08/10/17 08:11 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I'm looking at my stash of jacks and I know where some of them came from but that does not always mean the are OEM to that car. Looking at my 69-71 parts book, they list the same part number for all, except the charger. My question is the length of the post. I have b,c and a charger jack or two. I know the charger jacks but the lengths are throwing me. Does anyone have the lengths listed of the post for each body ?
Re: Mopar t post jscks [Re: fastmark] #2352759
08/12/17 11:07 AM
08/12/17 11:07 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Surely someone know the different lengths of the post or st least where to find it.
Re: Mopar t post jscks [Re: fastmark] #2353092
08/13/17 06:48 AM
08/13/17 06:48 AM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
How about listing the various lengths you have?
I have one 33 5/8".
Re: Mopar t post jacks [Re: 4mayhemi] #2353110
08/13/17 09:55 AM
08/13/17 09:55 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I have one 33 5/8".
I'll do that later todayπŸ‘
Re: Mopar t post jacks [Re: fastmark] #2353171
08/13/17 12:41 PM
08/13/17 12:41 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
hi,
as with many original parts there was a margin of acceptance, so understand there isnt going to be 1 correct answer
here is what i have found in original cars:
(t-type if not noted tube)
67-9 Cuda Jack Mast Length 33-1/2”
68-70 Charger Jack Mast Length 36” (2 CHECKED OUT AT 36”)
Superbird 34-3/4”
70 Challenger 34-5/8”
70 Cuda Tube 35”
66 Satellite Tube 34-1/2”
i hope to have my new t-type jack assemblies available by winter
Re: Mopar t post jacks [Re: fastmark] #2353182
08/13/17 01:09 PM
08/13/17 01:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 Coronet 4-door - 33 9/16"
Re: Mopar t post jacks [Re: fastmark] #2353237
08/13/17 03:06 PM
08/13/17 03:06 PM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
So if the T post was mostly from Hamtramck/Lynch Rd, how many vendors would there have been? I don't see why there would be a consistent 1/2" difference between a 70 Cuda/Chally.
Also, are all the posts you guys see a little "rounded" on the ends (teeth side)? I always assumed this is from use, but have you guys seen any non-restored ones that are completely square on the end? Maybe it was shaped this way from the process of cutting long stock?
Re: Mopar t post jacks [Re: fastmark] #2353338
08/13/17 08:18 PM
08/13/17 08:18 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Here are my jacks with known application with 99% certainty
68 Coronet 4 dr. 33 11/16" black
68,69,and 70 Chargers all 36 1/8" and Grey
69 NYer 34 5/8 grey
68 Fury III 34 5/8 grey
My probables are
68 Coronet 2 dr. 33 5/8 black
My unknowns are
2@ 34 5/8 one black one grey
36 7/8 black
33 11/16" black
38 1/4 heavy duty post blue
I have two AAR with no jacks so that is where this is going.
Re: Mopar t post jacks [Re: fastmark] #2353340
08/13/17 08:26 PM
08/13/17 08:26 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
A customer needs a jack for a 70 Challenger so I started looking at mine. It's an early build so I figured on the t post.
My 70 Satelite St Louis car has a 35 1/4" tube style.
Re: Mopar t post jacks [Re: fastmark] #2353342
08/13/17 08:34 PM
08/13/17 08:34 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
So if I Cuda hear from some Cuda owners with jacks, I think I'd be able to call this. Looks like most b and e's are in the 33.5 to 34.5 range.
Re: Mopar t post jacks [Re: fastmark] #2353871
08/14/17 08:42 PM
08/14/17 08:42 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I have two Cuda jacks and they are 35 1/4" long.
Re: Mopar t post jacks [Re: 5carguy] #2353995
08/15/17 12:30 AM
08/15/17 12:30 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Hmm I would have thought they were 33 1/2". Maybe because the bumpers are smaller and higher off the ground. And these are t post not tube, correct?
Are Challengers the same lengths as cudas?
Thanks for the help.
Re: Mopar t post jacks [Re: fastmark] #2354428
08/15/17 07:53 PM
08/15/17 07:53 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
These are tube jacks
Re: Mopar t post jacks [Re: 5carguy] #2354600
08/16/17 01:25 AM
08/16/17 01:25 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Yes, thanks. I was just clarifying that both your cuda jacks were t post that were 35 1/4 long. I don't have any that long that are t post. Except one really long one.
Re: Mopar t post jacks [Re: fastmark] #2356474
08/19/17 11:12 AM
08/19/17 11:12 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
I'm looking for jack for challenger built date 10/69. I should be looking for T style 34 5/8 .. yes ? ?
thanks
Re: Mopar t post jacks [Re: fastmark] #2357041
08/20/17 11:53 AM
08/20/17 11:53 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well after posting on three sites, I think I found out a few things. I was surprised I got no responses from the A12 board. I think those jacks are 33 1/2", though.
Most 70 ebody jacks are the post type but there are exceptions. I have determined that one of my jacks I just picked up in a big parts trade is in fact, either from a 70 Cuda or a 70 Challenger. He had a Cuda since high school and the hook I got with it matched in color with the Cuda part number. I can't help but believe the Challenger uses the same length mast. There is a good informative post on for e bodies only with a mostly accurate chart about jacks. In short, I believe e body jacks are longer than B body jacks. So the 34.5 to 35 seems like an acceptable length. That is the same length and style of jack that I have confirmation that came out of two c bodies I am certain of the origin. Dates are too early but I have found that not all jacks have dates on them.
Re: Mopar t post jacks [Re: fastmark] #2357049
08/20/17 12:11 PM
08/20/17 12:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Jack masts from 1968 or so back typically do not have date codes.
Re: Mopar t post jacks [Re: Alaskan_TA] #2357301
08/20/17 10:30 PM
08/20/17 10:30 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That is what I have found on my known 68 jacks.
Re: Mopar t post jacks [Re: fastmark] #2656971
05/19/19 06:48 PM
05/19/19 06:48 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
where would the date codes be on a e-body
One i have think it came out of a 71 Barracuda measures 35 1/4 " long
It has a patent # #3163925 .It is a tube type
Re: Mopar t post jacks [Re: GVH] #2657021
05/19/19 08:55 PM
05/19/19 08:55 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
They are stamped on the side of the jacking mechanism. I don’t have any pictures but a typical code would be K 9 meaning dec of 69.
