#2350246 - 08/07/17 05:01 PM Best rear main and trans pan seals '79 Power Wagon 360/727
larrymopar360 Offline
Loc: Central Florida
Please recommend the best rear main seal and 727 trans pan gasket for my '79 Power Wagon. I'm hoping there is a bit of a consensus on what's the best brand/type. I already have a good oil pan gasket (Superformance).
Will be digging in soon to stop all the leaks.
Thanks.
Larry
Facts are stubborn things.
#2350867 - 08/08/17 04:06 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360]
scratchnfotraction Offline
Loc: Florida
get the seal from superformance. makes a nice orange seal for no leaks.
I would use all gaskets from superformance they seal really well.
best gaskets for the $$ IMHO.
#2351481 - 08/09/17 04:40 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: scratchnfotraction]
That's all I needed to hear. Ordering now.
Thanks buddy.
#2351527 - 08/09/17 06:03 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360]
Superformance no longer has rear main seal kits. I just called. frown
#2353107 - 08/13/17 07:46 AM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360]
135sohc Offline
Loc: SoMd, USA
chrysler 2464324AC for 727/46/47/48 series transmission
Nothing else comes close.
#2353293 - 08/13/17 03:31 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc]
Thank you very much.
#2353295 - 08/13/17 03:43 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc]
This is for my '79 Power Wagon with factory 727.
My search of this part number shows this number not compatible? Only compatible with the 46RE 47RE 48RE. Is this accurate? Is the pan the same?
Thank you.
#2354263 - 08/15/17 01:05 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360]
135sohc Offline
Loc: SoMd, USA
The pan on a 727 and 46/47/48 series are the same outline shape. The 2464324AC has some added thickness to it, you might need slightly longer bolts to get full thread engagement into the case.
#2354496 - 08/15/17 08:20 PM Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc]
OIC, thx.
25,383 Registered Members
190,992 Topics
Hemi 4 speed trans v.i.n id
by artie717
07/21/18 03:01 PM
The Chrysler Convention Car show in CT August 5th 2018
by steve70
07/21/18 12:46 PM
Part number ID help
by 318 Stroker
07/21/18 12:08 PM
Damper & MSD crank Trigger
by RATTRAP
07/21/18 11:43 AM
