6.1 piston pin and locks... #2351163
08/09/17 04:23 AM
08/09/17 04:23 AM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Does anyone know what the STOCK weight for the 6.1 Hemi wrist pins and locks are? I would guess the locks to be approximately 4 grams for the pair, but I cannot find a stock weight for the wrist pins. I know they are 1mm larger than the 5.7 wrist pins, but I can't find any weights on Google thus far.
Through help here on Moparts and Google searching I have found stock 6.1 connecting rods weigh in at an average of 653 grams and stock pistons weigh in at an average of 435 grams.
I appreciate any help...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 6.1 piston pin and locks... [Re: sycboi] #2352063
08/10/17 08:25 PM
08/10/17 08:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'll weight the rod and pin and locks separately tomorrow.
Matt
The pin is a tapered design.
Re: 6.1 piston pin and locks... [Re: MattW] #2352266
08/11/17 02:40 AM
08/11/17 02:40 AM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Thank you good sir!
SuperBeast
Re: 6.1 piston pin and locks... [Re: sycboi] #2352461
08/11/17 04:30 PM
08/11/17 04:30 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
So from the scale at work.
Rod with bolts and cap=652 grams
Pin and locks= 154 grams
Pin =152
Wouldn't register the locks by themselves.
Matt
This scale is not a calibrated scale so........
Re: 6.1 piston pin and locks... [Re: MattW] #2352463
08/11/17 04:41 PM
08/11/17 04:41 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Great information. Thank you good sir. I appreciate you taking your time and doing this...
SuperBeast
Re: 6.1 piston pin and locks... [Re: sycboi] #2352567
08/11/17 07:45 PM
08/11/17 07:45 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
No problem
Matt
