Best rear main and trans pan seals '79 Power Wagon 360/727 #2350246
08/07/17 07:01 PM
08/07/17 07:01 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Please recommend the best rear main seal and 727 trans pan gasket for my '79 Power Wagon. I'm hoping there is a bit of a consensus on what's the best brand/type. I already have a good oil pan gasket (Superformance).
Will be digging in soon to stop all the leaks.
Thanks.
Larry
Facts are stubborn things.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360] #2350867
08/08/17 06:06 PM
08/08/17 06:06 PM
scratchnfotraction Offline
get the seal from superformance. makes a nice orange seal for no leaks.
I would use all gaskets from superformance they seal really well.
best gaskets for the $$ IMHO.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: scratchnfotraction] #2351481
08/09/17 06:40 PM
08/09/17 06:40 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
That's all I needed to hear. Ordering now.
Thanks buddy.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360] #2351527
08/09/17 08:03 PM
08/09/17 08:03 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Superformance no longer has rear main seal kits. I just called. frown
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360] #2353107
08/13/17 09:46 AM
08/13/17 09:46 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
chrysler 2464324AC for 727/46/47/48 series transmission
Nothing else comes close.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc] #2353293
08/13/17 05:31 PM
08/13/17 05:31 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you very much.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc] #2353295
08/13/17 05:43 PM
08/13/17 05:43 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
This is for my '79 Power Wagon with factory 727.
My search of this part number shows this number not compatible? Only compatible with the 46RE 47RE 48RE. Is this accurate? Is the pan the same?
Thank you.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: larrymopar360] #2354263
08/15/17 03:05 PM
08/15/17 03:05 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The pan on a 727 and 46/47/48 series are the same outline shape. The 2464324AC has some added thickness to it, you might need slightly longer bolts to get full thread engagement into the case.
Re: Best rear main and trans pan seals '79 Power Wagon 360/727 [Re: 135sohc] #2354496
08/15/17 10:20 PM
08/15/17 10:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
OIC, thx.
