Re: Fun handling with a slush box? Stuck with a Torqueflight..
[Re: MRGTX]
#2350638
08/08/17 12:23 PM
08/08/17 12:23 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
No impediment at all, go have fun with it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: MRGTX]
#2350799
08/08/17 04:18 PM
08/08/17 04:18 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Just make sure the automatic trans has manual override (shift kit, yet still fully automatic when in drive). You'd probably use 2nd gear the majority of the time for brisk driving through winding roads, pending the mph speeds. My 727 is a great (Transgo shift kit, BM holeshot ~2400 stall)... bullet proof! Even when I drive on local streets/suburbs, etc, I use 2nd gear (1st/2nd) most of the time; 3rd gear for the steady upper mph (~35-45-55 up).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: MRGTX]
#2351215
08/09/17 10:26 AM
08/09/17 10:26 AM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
Well, this is good to hear, guys. Thanks. When I look at the fun I've had in carving up curves, working the transmission has always been half the fun. I guess it's a matter of expectations. Do any of you guys autocross with automatics? Is it ok to just leave it in 2nd and wail on it? I just saw a vendor who sells a Tremec T6060 conversion kit for ~$8000...this would triple the value of my Dart!
[Re: MRGTX]
#2351368
08/09/17 03:21 PM
08/09/17 03:21 PM
amxautox
Many times with my '98 SS/T. Yup, stick it in 2nd and leave it there, unless you are on a longer/higher speed course.
Tom
author unknown
[Re: MRGTX]
#2351397
08/09/17 04:05 PM
08/09/17 04:05 PM
Mopar Mitch
As MattAX has stated, shifting gears during a pylon AX only slows times down.. and disrupts the flow of the race course. Regardless manual or automatic, shifting slows down the times... and the automatic is always faster to shift... again, just add a shift kit (TransGo, other).
Mopar Mitch
[Re: Mopar Mitch]
#2351409
08/09/17 04:23 PM
08/09/17 04:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Go tell Ronnie that.
[Re: MRGTX]
#2351939
08/10/17 04:04 PM
08/10/17 04:04 PM
Mopar Mitch
Occasional downshifting also required... as well as turning the steering wheel l-r-l-r.. and braking, accelerating... etc Concentrate on driving the car... not shifting.
Mopar Mitch
[Re: MRGTX]
#2386316
10/12/17 02:59 PM
10/12/17 02:59 PM
Posts: 403 Colorado front range
BcudaChris
Hey guys, resurrecting this thread.
I'm having a lockup A999 built for my effort. Briefly, I'm setting up my 73 Barracuda as a "jack of all trades" with Power Tour (and One Lap if I can make that happen) in mind, as well as autox and track days and lots of street time. LA408, A999, 8.75 w/3.55 (may go to 3.23), 26.5" tires. I anticipate a shade under #3500 when it comes off the stands. I want the lockup for highway cruising RPM drop and reduced fluid temps(gear vendors will happen down the road as well). I want to automate the lockup with the vac/oil pressure switch method.
Anyway, I've never done OT or Autox with anything but a 5spd. My trans guy (noted Torqueflite specialist in my area) who primarily sets up beefy drag race slush boxes posits that an FM VP would be better for my purposes, particularly OT. Unfortunately, an FM VB will not use the governor circuit so I have to operate the lockup with a toggle switch, which I'd prefer not to do. I'm still coming to grips with the fact that the older I get the weaker my lifelong "stick shift or die" outlook on life becomes.
As Mitch has pointed out, 2nd is the bomb for autox and zipping around back roads. Having D also lets you focus on driving for OT efforts.
I'd like the thoughts of Brain Trust on tracking with a FM valve body v. keeping the "D" in my shift window.
Some questions I have, are there reliability issues that arise when manually grabbing 2nd for corner exit and bumping to D in certain situations when carrying speed or when manually shifting in the 1320? Are there any internal trans tuning tricks to delay upshifts until nearing redline at WOT? Are there other considerations I don't have the experience to take into account?
Let us discuss!
