Re: 1968 AM FM radio in 1969 B Body.
[Re: Morty426]
#2350347
08/07/17 10:45 PM
08/07/17 10:45 PM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
for '68 the b-body AM/FM was an accessory catalog item - not factory installed " CHRYSLER SOLID STATE" text on the '69 factory installed version Charger ONLY also had a high-powered 5-1/2 watt OPTIONAL AM radio
[Re: bdgtfb]
#2350388
08/07/17 11:42 PM
08/07/17 11:42 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
thanks for your reply. will the 68 fit my 69 car. also is the wiring the same for hook up? It will fit in your car. However the AM/FM requires special wiring and a control box. Wiring also depends on if you have 3 speaker dash and either 1 or 2 rear speakers.
