6.1 reluctor ring / tone wheel bolt source #2347142
08/02/17 06:08 AM
08/02/17 06:08 AM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
I am having one heck of a time finding these bolts. I have googled for days. They are not a tapered under-head bolt like the 5.7s. They have a flat head and a locating shank under the head. Anyone know where to buy them without buying a new aftermarket tone wheel just to get a bolt? Thank you for any help...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 6.1 reluctor ring / tone wheel bolt source [Re: sycboi] #2347337
08/02/17 03:05 PM
08/02/17 03:05 PM
dogdays Offline
dogdays  Offline
Are you talking about a shoulder bolt? They look like this:
R.
Re: 6.1 reluctor ring / tone wheel bolt source [Re: dogdays] #2347353
08/02/17 03:30 PM
08/02/17 03:30 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Yes sir. They are 6.1 Hemi specific I guess. The 5.7 tapered head bolts won't work on the 6.1 reluctor unfortunately...
SuperBeast
Re: 6.1 reluctor ring / tone wheel bolt source [Re: sycboi] #2348038
08/03/17 06:32 PM
08/03/17 06:32 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
You can't source them Mopar?
What about calling someone who sells the rings and asking them if they can order just the bolts>
Re: 6.1 reluctor ring / tone wheel bolt source [Re: sycboi] #2348071
08/03/17 07:21 PM
08/03/17 07:21 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Mopar wants to sell you an entire crankshaft. Obviously that's out of the question. My next move is to try and buy bolts from an aftermarket reluctor wheel manufacturer like you're suggesting...
SuperBeast
Re: 6.1 reluctor ring / tone wheel bolt source [Re: sycboi] #2348482
08/04/17 03:13 PM
08/04/17 03:13 PM
dogdays Offline
dogdays  Offline
If they are indeed shoulder bolts like the picture I posted they are a standard type of fastener. No need to go buying entire crankshafts. FCA doesn't make fasteners, they buy them from specialty manufacturers.
You need the diameter of the threaded part, the thread pitch, the diameter of the shoulder and the length of the shoulder from its end to the bottom of the bolt head. I'd start with Fastenal.
https://www.fastenal.com/content/product_specifications/STRIP.BO.pdf
This is just the first one that popped up. I'm sure they make hex head shoulder bolts. All available in both standard and metric sizes.
R.
