Page 31 of 33 1 2 29 30 31 32 33
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2326007
06/24/17 03:39 AM
06/24/17 03:39 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
It actually didn't drive too bad. I started to notice it slip a little
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2329844
07/01/17 06:02 PM
07/01/17 06:02 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I rechecked TDC and my balancer had slipped allot. Last time I checked it it was acurate to about .75 of a degree.
I pulled and locked out the advance in my MSD distributor recently and the car ran ok but toal timing was probably only about 15 degrees and timing was retarded slightly at idle.... so timing has been off since I installed the EFI.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2337969
07/16/17 08:30 PM
07/16/17 08:30 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I thought I'd share this. I recall a post and members discussing the proper finish of hood latches many years ago. I had mine off a few weeks ago and took these pics. Mine is a 12/71 built hamtramck built car
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2338339
07/17/17 01:27 PM
07/17/17 01:27 PM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
I'm pretty sure it's a silver/zinc finish for correctness...
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: 1972 340 4spd Cuda [Re: jpilone] #2338351
07/17/17 01:46 PM
07/17/17 01:46 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
What you see is how it came
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2346475
07/31/17 11:57 PM
07/31/17 11:57 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I like the fuel injection
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2346504
08/01/17 12:45 AM
08/01/17 12:45 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
How is it?
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2347075
08/02/17 01:09 AM
08/02/17 01:09 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
up up It's running well
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2347363
08/02/17 03:53 PM
08/02/17 03:53 PM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
I am going to pull the trigger soon for the exact same fitech setup with the command center for my car. I'm sick of chasing the tune on my car. And I have the vapor return line on my car too.
-Jarrod Pilone
My Project Thread
Re: 1972 340 4spd Cuda [Re: jpilone] #2347489
08/02/17 09:27 PM
08/02/17 09:27 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
There are FiTech groups on FB, and long running post on FABO http://www.forabodiesonly.com/mopar/threads/fitech-efi-system.321984/ that should help.
Things to note
I was urged that running a ground to the unit would be a good idea. Shown is the one I used, I got it at NAPA and I did have to enlarge one hole slightly. This fit nicely from a carb stud to the back of the head on a smallblock
I was also told that one or two users had codes that they eliminated by shielding wires. Shown previously is what I used to shield my wires. PM me if you need a source.
I also found the straight vent nipple to be awkward so I bought (what I think is) a 5/16ths 90 degree hose barb 1/8th male NPT
Pay close attention there's an arrow on the filter to shown direction of flow.... and one of the illustrations has the filter backward
Ground strap.jpgfive16ths   90 Degree Hose Barb one8th Male NPT.jpgfuel filter arrow.png
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2377492
09/27/17 12:37 AM
09/27/17 12:37 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I adjusted my pinion angle 2 degrees using shims. The second pic shows things loosened up, I swapped one U bolt at a time to keep things together.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2382746
10/05/17 11:14 PM
10/05/17 11:14 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I need to account for the large roller cam and vacuum, so ..... I sprung for a pricey dual flow PCV valve. It has idle and cruise circuits
I will need to change the grommet but I've spec'd everything and Napa should be able to help.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2382959
10/06/17 02:07 PM
10/06/17 02:07 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
How many of you guys are driving your cars? I use mine allot, I even use mine for corner store beer runs etc (as shown above) but today I was off and my wife asked me to pick up Groceries....check out my Grocery getter
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2383169
10/06/17 10:20 PM
10/06/17 10:20 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Nice! Hope all is going well!
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2383298
10/07/17 04:30 AM
10/07/17 04:30 AM
New Mexico
Geo4K Offline
Geo4K  Offline
New Mexico
Where's the beer?
Re: 1972 340 4spd Cuda [Re: Geo4K] #2383375
10/07/17 12:52 PM
10/07/17 12:52 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Going well, I've been enjoying it. I'm sure a few drivers were surprised to see it come into and out of view rather expeditiously. I get "sounds good man" texts as I exit or enter the neighborhood,my Chevrolet buddy can hear it from his house smile
Originally Posted By Geo4K
Where's the beer?
The evidence is in the recycle bin, I've made 4 beer runs since Thursday.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2384022
10/08/17 06:14 PM
10/08/17 06:14 PM
New Mexico
Geo4K Offline
Geo4K  Offline
New Mexico
Dude, 4 beer runs? Sounds like the Cuda isn't big enough then - better start using the Ram.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2384065
10/08/17 07:46 PM
10/08/17 07:46 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Just went to Marble today with Mo (in her Dart), watched the Giants lose again and grabbed a growler.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2390636
10/21/17 01:34 AM
10/21/17 01:34 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I needed a 1" OD, 3/4" ID grommet. It took a bit but I found one.
Re: 1972 340 4spd Cuda [Re: UCUDANT] #2390677
10/21/17 03:45 AM
10/21/17 03:45 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I measured, measured and measured, made a baffle/tapped the bosses, shortened the screws, used star washers and locktite etc. The baffles is very tight tolerance to the vlave cover.
