If you’ve heard of the TV show Graveyard Carz, then we’re sure you’ve heard of their famous “Phantom ‘Cuda.” If you haven’t heard of the car, the Phantom ‘Cuda is a very rare and desirable 1971 Plymouth ‘Cuda powered by a 440-6 Barrel 4-speed. This is the car that originally started the TV show that has now taken off and is watched all over the world. The crew from the show used the car as a promotional item years ago, burying the ‘Cuda in dirt and then using their big block Mopar powered Herse to drag it out of its “tomb.”
Read the whole story at Mopar Connection HERE:
