Re: Starting to work on the Duster
[Re: AndyF]
#2343545
07/26/17 09:40 AM
07/26/17 09:40 AM
Posts: 4,035 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
As far as I can tell if you have a 5 point (or 6 point) roll bar then the main hoop needs to be 1 3/4. That is good to 10.00.
The 8 point cage can be 1 5/8 mtl and is required if you get into the 9's.
The main hoop on this cage is 1 5/8 so I think I'm just going to cut the whole thing out and start over.
Any recommendations for a roll bar kit? I see that Jeg's has them, Art Morrison, Comp Engineering, etc. From what I can tell all of the kits are really crude with no fishmouthing on the tubes or anything like that. It is basically just a bunch of straight tubes in a box plus the main hoop. The rest is DIY. I have put 2 of Chris Alston Chassisworks kits in A-bodies. I think they do a good job for a decent fit especially the main hoop AND side door-bar fit. I have helped install a Jeg's kit in an A-body...it fit poorly. It would be nice and package easier (save time with tin) if you had the rear bars bent to go thru the speaker package tray and weld them down near where a shock crossmember could be intersected. For future owner of course. Call BondoBob...I'd bet he would bend and pre-fit a cage and drop it in the mail..worth a call anyway.
[Re: AndyF]
#2343549
07/26/17 10:06 AM
07/26/17 10:06 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Used a Chris Alston kit in my cuda. Fit pretty good. The chassis shop I used said those kits fit the best out of the pre bent kits you can buy.
[Re: AndyF]
#2343587
07/26/17 11:16 AM
07/26/17 11:16 AM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
I have use Alston CHassisworks kits in three A bodies. They fit decent but I had the rear bars bent to go through package tray, which required buying longer rear bars. Also had the front bars bent to better fit the door opening. My goal is to try and hide the cage as much as possible and I am fairly tall so I end up putting the main hoop back a ways too.
[Re: AndyF]
#2343706
07/26/17 02:35 PM
07/26/17 02:35 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Buddy of nine has installed several S&W kits and likes them over anything else for A body.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2343844
07/26/17 07:09 PM
07/26/17 07:09 PM
fullmetaljacket
This car sits ready wit to me with a nice size tire at that. I would bet it to be an excellent starting platform for whom ever gets it. Looking at the Coronet in the background, one may wonder what kind of animal that will be.
[Re: AndyF]
#2343996
07/26/17 11:55 PM
07/26/17 11:55 PM
dartman366
Mt. Vernon, Ohio
I need to figure out a steering column for this thing. I looked around and Jegs has a simple tube with bearings and a steering shaft. The shaft is set up for a quick release steering wheel on the driver side, can't really tell what is going on on the other end.
Anyone have a race type steering column that they used and liked? I'm guessing that I'll need to weld a Mopar spline adapter on to the box end then shorten the shaft to length and weld the quick release on the driver end?
I'll need turn signals but maybe I need to mount up an old time box on the column. I suppose you can still buy those old turn signal switch boxes. Andy, thats the same column kit I put in my car last winter and I like it, plenty of material to set the wheel where you want,also comes with a short piece of moly tube and a smooth bore universal so it can work with a rack and pinion steer, I also had to order the mopar spline universal to attach the column to the stock gear box, the steering wheel hub is the multi spline set-up and not the hex style.
[Re: AndyF]
#2345294
07/29/17 03:12 PM
07/29/17 03:12 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Halo = half (partial) of the top I've seen and possibly owned one as a parts car
[Re: AndyF]
#2345377
07/29/17 06:40 PM
07/29/17 06:40 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Finally got some stuff cleared out and blew away the cobwebs so I could shoot a picture of the interior. Like I said, this car is gutted!
I'm not going to put much back in the car. Pedals obviously and a steering column and the top part of the dash with the dash pad and the VIN. That is about it, bare bones.
Good thing is that it is fairly clean. No rust problems to speak off and nothing has been hit or tore up. Just a few extra holes in the firewall that people drilled over the years but that is not a big deal. It's so awesome starting with a clean base project. Seeing that pic makes me have "non-buyers" regret...
[Re: AndyF]
#2345428
07/29/17 08:53 PM
07/29/17 08:53 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
With the dash and all the interior out of the car I would suggest you put a cage in the car, not just a roll bar. Then you could have more options.
Looks like a good excuse to buy a bender. I am sure you can find other parts to make with it.
"Just a Bracket car dressed up like a streetcar"
[Re: AndyF]
#2345463
07/29/17 10:31 PM
07/29/17 10:31 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
If you don't mind me asking, how much do those digital scales cost, looking to invest in a set like it. On the roll bar, I found out mine are too small, now ill have to do the full cage( 2 down bars and a halo) anyway they say it'll be better for resale.
