air bag suspension in a Mopar A-body #2340754
07/21/17 01:27 AM
07/21/17 01:27 AM
440dustr Offline OP
440dustr  Offline OP
hi
I am thinking of installing a ridetech airbag suspension in my 1970 duster to make it a smoother ride. I know what I need for my 4 link setup in the rear my issue is the front upper control arms dont allow much room anyone do this to an A body and if so what did you do to get it to fit. thanks
Re: air bag suspension in a Mopar A-body [Re: 440dustr] #2340788
07/21/17 02:55 AM
07/21/17 02:55 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think you'll want to move this post to the Handling tech suspension forum.
Re: air bag suspension in a Mopar A-body [Re: StealthWedge67] #2341075
07/21/17 06:08 PM
07/21/17 06:08 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Not much there about air bag suspensions. Four links aren't either, I'm in the cornering forum a LOT. Most are stock suspension based with a few triangulated 4 links or custom 3 links. To the OP, measure twice, cut once. What someone could, or could not, fit on their car will have little to do with what you have to do. Click the Google search on the site and good luck. wave
Re: air bag suspension in a Mopar A-body [Re: 440dustr] #2341373
07/22/17 09:41 AM
07/22/17 09:41 AM
moparx Offline
moparx  Offline
you more than likely, will need to use aftermarket upper control arms for added clearance around the bags. you may also need to alter the inner fender structure to safely support the weight the bags will be carrying.
beer
