Will 18in Durango wheels fit Dakota? #2339444
07/19/17 12:40 AM
07/19/17 12:40 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
I want to upgrade my 16in to 18in. Both are 5.5in bolt pattern. thaks
Still looking for LM29H1B415501, '71 Demon 340
Re: Will 18in Durango wheels fit Dakota? [Re: PAULS_340] #2339777
07/19/17 03:45 PM
07/19/17 03:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen 15s 16s 17s 18s 19s 20s and 22s on durangos, just got to get the right tires and as far as I know only the dakotas durangos and vipers share the correct bolt pattern in all the world.
Re: Will 18in Durango wheels fit Dakota? [Re: PAULS_340] #2339836
07/19/17 05:01 PM
07/19/17 05:01 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
I assume you have a ND (2005-2011) Dakota. It shares bolt pattern with HB (2004-2009) Durango and Rams from at least 2002. They all use the same hub I believe.
The offset is slightly different between the Durango and Dakota, the Durango has about 12 MM more positive offset. The wheels should work, but double check your tire clearance.
