Moving Radiator
#2338355
07/17/17 01:53 PM
07/17/17 01:53 PM
Posts: 1,545 Michigan
Kiddart
Hi all, Just wondering if anyone has moved there radiator in front of the rad support and just behind the Grill. I have a 74 Dart Sport and have been thinking of doing this for a few years to free up some space.
What say you and share pics if you have them
Thank you Kiddart
Re: Moving Radiator
[Re: Kiddart]
#2338488
07/17/17 05:37 PM
07/17/17 05:37 PM
Posts: 4,205 New York
polyspheric
New York
No personal, but you're shifting a lot of weight in the wrong direction.
Boffin Emeritus
Re: Moving Radiator
[Re: Kiddart]
#2338656
07/17/17 10:07 PM
07/17/17 10:07 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I usually leave the line wheels up so I'd do it if I needed to but have plenty of room and street car, no problem I see........... How much are we really talking here anyhow..........
Re: Moving Radiator
[Re: Kiddart]
#2338666
07/17/17 10:19 PM
07/17/17 10:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have on my old Valiant.. was a destroked 383.. worked out great with a tube chassis but try to look at where the weight will be in the end
Re: Moving Radiator
[Re: MR_P_BODY]
#2339036
07/18/17 01:08 PM
07/18/17 01:08 PM
RapidRobert
there's been mention of a Hayden short fan assy (I forget the #). the legs on a BB pump can be milled. the "cross" on the WP can be pressed rearward a bit to move the pulley rearward along with buttonhead pump mounting bolts. The hardest part will be locating the correct depth pulleys to restore belt alignment. maybe even a rad with less cores (or just thinner) & a wider one to restore cooling capacity & "area" is more important than cores & it is for sure easier to expand clearances out sideways against the frame rails for more area.
Re: Moving Radiator
[Re: Kiddart]
#2339100
07/18/17 02:16 PM
07/18/17 02:16 PM
Posts: 17,916 Akron, Ohio
ProSport
Akron, Ohio
On my 73 dart with a big block, motor plate, mezeire pump and HHR fan with aluminum radiator I had to do some cutting on my core support to gain about an inch of room.
Re: Moving Radiator
[Re: Kiddart]
#2340791
07/21/17 03:10 AM
07/21/17 03:10 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Big aluminum Radiator. Engine plate, the Big GPM mezeire. Brothers ran out of room on the Ruster Duster. They were also in a hurry, so it wasn't pretty.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
