1/2 hard line to -6 AN Braided Hose #2338169
07/17/17 01:57 AM
07/17/17 01:57 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I'm planning to install a 1/2 inch line in my car when I install an electric pump. I've got -6 hose from my mechanical pump right now, just bought the hose and fuel filter last year. I don't really want to drop another $200 bucks for more stainless hose, fittings, and fuel filter.
Is there an easy way to adapt the 1/2 inch line to accept a -6 hose? I don't really need the 1/2 inch line but I don't want to go through the trouble of running a new line and use 3/8.
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338174
07/17/17 02:26 AM
07/17/17 02:26 AM
I would buy the female hydraulic steel fitting (nut and sleeve) to put on the 1/2 line, if it is steel, aluminum fittings if it is aluminum, and a #6 to #8 male union and hook the two lines together up scope
I've done that with larger AN lines with no issues wrench
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338232
07/17/17 10:43 AM
07/17/17 10:43 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Without Data, you’re just another guy with an opinion.
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338358
07/17/17 02:07 PM
07/17/17 02:07 PM
you might checkout speedway motors online catalogue/pics.
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338556
07/17/17 07:28 PM
07/17/17 07:28 PM
Is the half inch line metal or hose?
If metal is it aluminum, steel or stainless steel?
I use soft aluminum lines a lot on both my street and strip only cars and I use the AN fittings on them, I did use steel on my current street project car and it was a lot harder to work with bending, forming and making it fit the car like the original line did whiney Aluminum would have been a lot easier and quicker shruggy
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338570
07/17/17 07:51 PM
07/17/17 07:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I haven't bought it yet cab but was thinking aluminum
Re: 1/2 hard line to -6 AN Braided Hose [Re: GTX MATT] #2338702
07/17/17 11:05 PM
07/17/17 11:05 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Don't mess around with more connections to cause leaks, I use the correct fittings and AN flaring tool! The D suffix means aluminum. Just delete the D for steel. Parker sells steel one under the JIC standard.
AN815-8D
AN818-8D
AN819-8D
and a rotoflare!
after reading your post, the half inch hard line would be severely restricted with -6 hose, you would want -8
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
