Page 9 of 12 < 1 2 7 8 9 10 11 12 >
#2338048 - 07/16/17 08:37 PM 1971 383 2 BARREL KICK DOWN LINKAGE [Re: moparts]
littleredcoffin Offline
Loc: NH USA
THIS CAME OFF AN E BODY 383 2 BARREL ENGINE.ITS ALL HERE,EVEN THE SMALL TENSIONER SPRING.$45,CALLS ONLY 603 209 1678.PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2338051 - 07/16/17 08:41 PM 1971 RALLY DASH WIRING HARNESS VERY NICE NEVER REPAIRED $125 [Re: moparts]
Loc: NH USA
1971 RALLY DASH WIRE HARNESS.NON A/C .AUTOMATIC CAR.NO CUTS.NO HOT SPOTS.NO REPAIRS...FUSE PANEL IS NOT RUSTY.THIS IS AS GOOD AS IT GETS,BEING USED.$125.CALLS ONLY 603 209 1678.PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2338055 - 07/16/17 08:43 PM 1971 BIG BLOCK VALVE COVER SET [Re: moparts]
Loc: NH USA
1971 383 VALVE COVERS.OFF 2 BARREL ENGINE.WILL WORK FINE ON ALL 383/440 ENGINE.NEED TO BE CLEANED..NOT RUSTED OUT,NOT DENTED..$40PR,CALLS ONLY 603 209 1678
#2338060 - 07/16/17 08:49 PM 383 ACCELERATOR CABLE [Re: moparts]
Loc: NH USA
383 CABLE,CAME OFF 2 BARREL ENGINE.NOT SURE THE DIFFERENCE ,IF ANY IN A 4 BARREL APPLICATION.WORKS FINE$15,CALLS ONLY 603 209 1678
#2338069 - 07/16/17 08:56 PM 1971 TRIPLE NIPPLE VALVE COVER BREATHER [Re: moparts]
Loc: NH USA
1971 3 NIPPLE BREATHER.CORRECT FOR `71 ONLY..340/383.$20,CALLS ONLY 603 209 1678,PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2338070 - 07/16/17 09:01 PM CHALLENGER HEADLIGHT WIRE HARNESS [Re: moparts]
Loc: NH USA
GOOD USED HARNESS..I SEE NO CUTS.$10,CALLS ONLY 603 209 1678.PAYMENT BY US POSTAL MONEY ORDERS
#2338071 - 07/16/17 09:03 PM AUTOMATIC NEUTRAL SAFETY SWITCH HARNESS [Re: moparts]
Loc: NH USA
AUTOMATIC TRANSMISSION NEAUTRAL SAFETY SWITCH HARNESS.I SEE NO CUTS OR DAMAGE.$10,CALLS ONLY 603 2091678.PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2338073 - 07/16/17 09:06 PM 383 ENGINE WIRE HARNESS [Re: moparts]
Loc: NH USA
1971 383 ENGINE WIRE HARNESS..1 COIL WIRE HAS SOME DAMAGE.THATS THE ONLY THING WORNG WITH IT.$20.CALLS ONLY 603 209 1678,PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2338075 - 07/16/17 09:08 PM 71 CHALLENGER GRILLE SUPPORT BRACE [Re: moparts]
Loc: NH USA
NEEDS TO BE GLASSBED.$10,CALLS ONLY 603 209 1678.PAYMENT BY US POSTAL MONEY ORDERS ONLY
Edited by littleredcoffin (07/16/17 09:42 PM)
#2338078 - 07/16/17 09:11 PM BIG BLOCK COIL BRACKET [Re: moparts]
Loc: NH USA
BIG BLOCK COIL BRACKET,NO DAMAGE.$10,CALLS ONLY 603 209 1678
#2338235 - 07/17/17 08:46 AM 1970 E-Body Power Steering Shaft [Re: littleredcoffin]
70plymA34 Offline
Loc: Long Island, NY
1970 E-Body Power Steering Shaft. Measures roughly 41" end to end. Light pitting.
Not Collapsed.
$40 +S&H.
Mike
516-250-2366
shaker426@aol.com
Edited by 70plymA34 (07/17/17 08:56 AM)
Super Commando
#2338250 - 07/17/17 09:05 AM NOS 1970 A & E Body AC Condensor Coil 2812 689 [Re: 70plymA34]
70plymA34 Offline
NOS 1970 A & E-Body AC Condensor Coil. Comes with coil, directions and original box.
$99 +S&H
Mike
516-250-2366
shaker426@aol.com
Super Commando
#2338349 - 07/17/17 11:40 AM E-body [Re: moparts]
Claudia Offline
Loc: Ohio
E-body Parts Lot - $450 OBO
Used - Battery Tray Support Brace – 70-72 B and 70-74 E
Used - Front Shock Mounting Hardware Set
Used – Lower Steering Column Seal Retainer – 71-73 B and 71-74 E
New – Two Speed Wiper Motor Harness – 71-72 B and 70-73 E
New – Wiper Motor Nuts – A, B, C and E
Used – Three Speed Wiper Motor – 68-71 B and 70-74 E
Used – Main Drive Wiper Arm Linkage – 70-71 E
Used – Windshield Wiper Pivot – 70-74 E
Used – Front Windshield Lower Corner Trim Molding (LH) – 70-74 E
New / Used – Floor Heat Shield
Used – Manual Windshield Washer Pump – 70-74 E
Used – Rally Dash Clock Reset Cable – 70-71 E
Used – Switch Panel Mounting Plate – 70-74 E
Used – Standard Dash Switch Panel Bezel – 70-74 E
Used – Rally Dash Switch Panel Woodgrain Fascia – 70-74 E
Used – Rally Dash Gauge Cluster Woodgrain Fascia – 70-71 E
Used – Standard Dash Heater Control Bezel – 70-74 E
New – Exterior Mirror Retainer Hardware Kit – 71-73 B and 70-74 E
New – Exterior Mirror Gasket Set – 71-74 E
Used – Exterior Mirror Gasket – 73-74 B
Used – Ignition Switch (missing connector) – 70-74 E
Used – Key Buzzer Switch (missing connector) – 70-74 E
Used – Ignition Key Lock Cylinder w / Keys – 70-71 E
Used – Interior Door Handle (LH)
Used – Armrest Pull Cup Bracket – 70-74 E
Used – Door Lock Lever Set – 70-74 E
Used – Dome Light Assembly
New / Used – Vinyl Decal Application Kit (spray and gel)
New – Door Lock Cylinder Gasket Set
Used – Door Lock Link Rod (LH) – 70-74 E
New / Used – Quarter Window Roller Kit – 70-74 E
Used - Exterior Rear Lower Window Trim Piece (LH) – 70-74 Barracuda
Used – Exterior Rear Lower Window Trim Piece (RH) – 70-74 Barracuda
Used – Exterior Rear Upper Corner Window Trim Piece (LH) – 70-74 Barracuda
Used – Trunk Latch Striker Plate
New – Hooded Paint Suits
#2338717 - 07/17/17 09:26 PM Re: E Body - Parts For Sale - 3rd Quarter [Re: moparts]
67gtxnut Offline
Loc: florida
I have a new reproduction hood release cable assembly for E-bodies using this type of release. It is still sealed in its original plastic bag. Retails for $75.00 to $80.00 but will let it go for $45.00 plus shipping in the US (at cost).
Please contact me at xram65@aol.com
Thanks Moparts,
#2338728 - 07/17/17 09:33 PM Re: E Body - Parts For Sale - 3rd Quarter [Re: moparts]
67gtxnut Offline
Loc: florida
I have for sale for 1972 Cuda, Barracuda and Challenger brand new Legendary bucket seat skins and rear seat skins in the original Legendary boxes (2). These have never been installed and are perfect.
The Legendary part numbers are:
Bucket skins AA72CBJ0010-100 (black) list @ $421.00
Rear skins AA72CBJ0040-100 (black) list @ $285.00
I will let the entire kit go for $450.00 plus shipping @ cost
Please contact me at xram65@aol.com or 727-432-4364 (EST)
Thanks Moparts,
#2338821 - 07/17/17 11:16 PM Re: E Body - Parts For Sale - 3rd Quarter [Re: moparts]
kdsmith07 Offline
Loc: Loganville GA.
71 cuda rallye hood scoops w/inserts in nice shape.been stripped & primed and ready to paint.no damage anywhere.all pins intact and has the plastic inserts also.asking 200 shipped.pm me if interested,thanks
#2339218 - 07/18/17 03:15 PM N96 340 SHAKER hoses 3462118 For sale [Re: moparts]
shaker340 Offline
Loc: Eastern Ontario
I have one original and 6 repro hoses for sale, plus factory drawing. Repro hoses made by Cooper rubber with modern rubber in 2001.
Asking $500 for all. I can be contacted by pm or mlacroix1@yahoo.ca
Thanks Moparts!
Mike
Edited by shaker340 (07/18/17 03:16 PM)
1964 D100
2008 Challenger SRT8
#2339278 - 07/18/17 05:10 PM NOS CUDA PARTS LOT [Re: shaker340]
JEJJ Offline
Loc: Western,NY
This is 1 lot of NOS 1970-1971 Cuda parts. Many are early first run assembly line correct parts not found today. I have been collecting these for my own car for the last 30+ years with no intention of selling. I am offering this as a lot. If you are doing an "OE" car this would be just the purchase for you. It would be a tough task to find all these early parts today, not to mention the time,money,gas and or shipping costs for each part.
I have done the work over 30 years, now is your chance to go back in time for this parts lot.
3403630.......complete right front side marker assembly
3403631....... " left " " " "
3403640...... " right rear " " "
3403641...... " left " " " "
3420618-9 .....NOS take-off front turn signal assemblies
3403236-7.....outer tail light bezels
3420836-7.....tail light lenses
3570071......." 'CUDA" tail panel emblem
2095501...... correct ballast resistor
3420839......license plate light lens
3403832......**mint survivor license plate assembly**
2984178......rallye "FUEL" gauge
2984180..... " "TEMP" "
2984181..... " "OIL PRESSURE" "
2984182..... " "CLOCK" "
2983092/3.. windshield washer bottle and electric pump
299816/7....outside door handles
2999813... .outer door handle gaskets
2998212/3...rally hood scoop inserts
2899342....gas pedal spring pad
2935375....hood pop-up spring
2950713/2950715...70 only ball type shifter and button
2677765...power steering gear shift seal-upper oil
**** restored original 1970 only gas cap****
2926327.....horn relay
3420884.....HD/LP warning buzzer
3420816-7 ....wiper arms......also have correct black button wiper blades with rubber
3515045......a727 valve body plate
2070933.....Dana housing to backing plated foam gaskets
2983649.....440 positive battery cable
2642913......J-11Y spark plugs
2445845......headlight mounting spring w/screw
3577870.....fuel pump gasket
2999950.....chrome inner door lock knobs
1858018.....*rebuilt factory original* pitman arm...1970 p/s
3404835.....rear exhaust hanger (insulators that bolt to the bottom of the trunk)
2535990.....front sway bar support loupes
3400836-7....1970 only shock plates Dana,8-3/4**********mint used,natural state********
3438219......440 distributor
2648008......large yoke for Dana
3461728......rear brake
2925322......battery tray
2534814......outer battery tray hold down
*********mint upper control arms******
3441022.....correctly restored blower motor date 3219
NOS 440 fuel pump rod
NOS green spring transmission shifter spring
1942248 / 3515920 big block 727 auto shield and cover
2891078.....power steering hose
3419000.....power steering belt...correct
2536121.....big block engine mounts
3420895......440 distributor lead
3462094......1970 valve cover oil breather (1 port)
2946079......valve cover oil grommet
3514330......440HP vacuum control
2525254......fuel filter dated 0850
1904850......correct ribbed rad. overflow hose
2926502......auto trans wiring
2258862......fuel tank ground strap
3418459......195 degree thermostat
2770380......3 speed wiper switch
2947219......cigar lighter
3420865.......dimmer switch
1881938.......floor high beam switch
2947305.......correct "white dot" headlight switch
2864325.......glove box lamp package
2947488.......key buzzer switch
2926327.......12V horn relay assy.
2823521........E-brake release knob
2765197.......chrome seat release knob
2583623.......black seat adjust knob
2899370.......727 auto trans lever
2947905.......70 only with knob
3419953.......1970-1 decklid glovebox lock set
2996053........E-brake pad
2947516........trunk light w/switch
1948396........leaf spring plastic squeak pads set of 13
2983078.......windshield washer squirters
2660315.......1/2" valve stem extensions
**** correct nos Pentastar, lower passenger fender****
2497500........reservoir cap
3431077.......NOS take-off 3 speed wiper motor....I put it on my 71 Cuda, when I added a shaker, sold the shaker and put the 2 spd motor back on. I never hooked the 077 motor up, never used it, was on the car 1 summer and the car was not driven even 200 miles......show ready.
3419820........passenger lower windshield molding w/screw
2884731........defrost cable
2096627........windshield washer under hood connector to nozzle hose w/yellow stripe
2965368,2965369,2965370,2965371 complete set of Cuda wheel opening molding
Reduced to $10,000 for the lot,this is the least I will take for the lot. I can send pictures if there is a particular part(s)you would like pictures of.
To the person who buys this parts lot, I will offer an NOS rim blow steering wheel in the box for an additional charge. The rim blow steering wheel is not for sale separately.
I can deliver to the Mopart Nat's to save the buyer shipping.
***I may start to sell off individual parts if there is enough requests***
Thanks again for the Ad Moparts!
bakurruda@aol.com
Edited by JEJJ (07/19/17 09:19 AM)
#2339448 - 07/18/17 10:46 PM 1971-UP CONSOLE FLOOR SHIFTER ASSEMBLY [Re: moparts]
Loc: NH USA
71-UP FLOOR SHIFTER..WITH CONSOLE BRACKETS.CONVERTING OVER TO FLOOR SHIFT.I HAVE IT ALL HERE,INCLUDING THE Z BAR,SHIFTER,LINKAGE AND CONSOLE BRACKETS... SHIFTER SELECTOR IS THERE TOO...ITS ALL HERE!!!! $90.YOU WONT BEAT THIS PRICE!!!.CALLS ONLY 603 209 1678...PAYMENT BY US POSTAL MONEY ORDERS ONLY
#2339451 - 07/18/17 10:49 PM SLAPSTICK SHIFTER HANDLE [Re: moparts]
Loc: NH USA
71-UP SLAPSTICK SHIFTER HANDLE.HAS A SMALL CRACK,WORKS FINE..$10,CALLS ONLY 603 209 1678.PAYMENT BY US POSTAL MONEY ORDERS ONLY
24,714 Registered Members
183,495 Topics
cancer wins again
by stumpy
14 minutes 20 seconds ago
Co2 refill
by JAKE68
34 minutes 0 seconds ago
Sunpro going bye-bye? Bosch???
by CompSyn
44 minutes 43 seconds ago
Ever feel used and abused by folks in the hobby?
by aspenrt360
58 minutes 51 seconds ago
