Page 2 of 4 < 1 2 3 4 >
#2334437 - 07/09/17 10:18 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
904 Small Block Street/Strip trans fresh rebuild new T/A RMVB w/CRT special spring to boost line pressure, Special spring in front drum to stop it from unwinding on top end,5-thin RR clutches/kolene steel's front drum,4-RR clutches/kolene steel's rear drum,New CRT 1.6 W flex RR H.D. reinforced KD band,new CRT RR rear band H.D. band strut,4.2 lever,New billet rear servo,stock front servo/W-2 springs,acc.blocked,low gear set W/4-pinon steel front/rear planetary,new deep pan,case modified vent moved to rear, external reg adj., converter access, modified oiling system,with lightened internals and new stock oil pump gear. Call or text for pics. Can deliver sat at Carlisle if half paid before event. 724-208-4570. $1,350
#2335386 - 07/11/17 02:12 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
Mopar stock low gear set with 4-pinion steel planets front/rear for 904 trans. $175 have 2-set up Transgo TF-2 shift kit for 727/904 just rebuilt $150. Call or text for pics can deliver to Carlisle. 724-208-4570.
#2335390 - 07/11/17 02:20 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
Mopar stock rebuilt 727 small/big block transmission and stock 904 small block trans $500ea.Call or text for pics details. 724-208-4570. Can take to Carlisle if half paid.Other trans and parts available.
#2336777 - 07/14/17 12:22 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
ehbody Offline
Loc: Toronto, ON
For sale. SOLD for $350
Two 4speed transmissions 23 spline and One transmission case
All are short tail. Probably for A-body or B-body.
One is disassembled, and probably missing small parts.
One empty case.
Also Small block bellhousing for 72-73 for 318 or 340 for ABE body. All threads are good and clean.
Could be for Roadrunner, Duster, Dart, Cuda or Barracuda.
Local Pickup Only in Toronto. :-)
Edited by ehbody (09/08/17 10:29 PM)
Shawn 70 AAR
#2337271 - 07/15/17 08:48 AM Sold [Re: moparts]
Robbins Offline
Loc: Joplin, MO USA
Thanks Moparts.
#2338291 - 07/17/17 10:01 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
cdp Offline
Loc: MO
New MP 727 deep chrome pan. Complete, less box. Correct extender, bolts, gasket, filter.
SOLD. Thanks Moparts.
Chrispy1971gtx@yahoo.com
816 726 4512
Edited by cdp (09/15/17 01:11 AM)
#2338323 - 07/17/17 10:55 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Jason B Offline
Loc: Mopar
1- Complete 904 Transbrake transmission with A&A Transbrake and Aluminum front drum. Transmission is complete and in the car running now has 8 passes since fresh rebuild no issues. $2000.00 OBO - SOLD
Contact Jason Buckner 936-577-1648
ALSO FOR SALE:
1- ATI- Transbrake convertor fresh 8 passes flashes at 5600 RPM. $750.00
1- Turbo action 8" trans brake converter 5800 flash neck has a crack needs to go back for service. 250.00 - SOLD
1- turbo action air shifter reverse pattern 300.00
1- turbo action shifter reverse pattern 150.00- SOLD
1- turbo action shifter console 25.00
Edited by Jason B (07/24/17 10:07 PM)
1968 Cuda 440" Edelbrock Victor Head Small Block.
#2338513 - 07/17/17 04:24 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
DudleyPerformanc Offline
Loc: North Carolina, USA
After Market Linkage Set Up out off a 71 Road Runner Drag Car.
Fits Hurst Shifter. Will Have to modify the tunnel.
$180
Located in Walkertown NC
(Near Winston Salem)
PM here or
Contact Mark
Shop 336-595-2000
cell 336-399-7262
[img:center]http://[/img]
Edited by DudleyPerformanc (08/30/17 08:49 AM)
Mark Dudley Performance and Parts
Complete Line of High Performance Parts
Engines, Transmissions, Front-End Rebuilds,
Rear-End Rebuilds and Disc-Brake Converstions.
"From Strip to Street * We Do It All"
#2338517 - 07/17/17 04:32 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
Mr Gasket Vertigate
4 Speed A833
$450
(near Winston Salem)
PM here or
Contact Mark
shop 336-595-2000
cell 336-399-7262
#2339093 - 07/18/17 12:08 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: DudleyPerformanc]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
made in the usa 1969-1989 904/727 neutral safety switchs with seals DODGE,PLYMOUTH,CHRYSLER$24 each mailed
cowgerwilliam035@gmail.com
Edited by Joesixpack (07/19/17 09:56 AM)
#2341712 - 07/22/17 08:44 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Rapid340]
Rapid340 Online   content
Loc: oberlin, Ohio
Hearst vertigate shifer, new
$395 plus shipping
jeffpatterson@copper.net
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2342185 - 07/23/17 09:13 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Rapid340]
kyle340 Offline
Loc: Louisville, Ky
1965-68 neutral safety switch for a 727, nos part #3004087 brand new still in the box, $65 email rtsalvage@att.net
#2343047 - 07/25/17 11:56 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: kyle340]
Joesixpack Offline
rebuilt v8 904 68 trans, cheetah RMVB,deep pan,mancini hp rebuild kit was used,was my spare.pick up in AZ$450
#2343051 - 07/25/17 12:01 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Joesixpack]
Joesixpack Offline
used 2.74/1.55 904 low gear set. complete $100 plus ups
#2343056 - 07/25/17 12:06 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: Joesixpack]
Joesixpack Offline
Fits: A904
Chrysler 2.250 in. Depth; Incl. Magnetic Drain Plug
Transmission Pan Material: Aluminum
Transmission Pan Finish: Natural
Transmission Pan Style: Deep
Drain Plug Included: Yes
Filter Extension Included: Yes
Filter Included: No
Gaskets Included: No
Bolts/Studs Included: Yes
Temperature Sender Bung Included: No
Quantity: Sold individually.
Notes: Fully fabricated from lightweight aluminum and features a one-piece billet rail.
Moroso has turned its attention to the design and manufacturing of premium-quality transmission pans. Moroso transmission pans are fabricated entirely from lightweight aluminum and feature a one-piece billet rail to ensure leak-free sealing. Precise CNC manufacturing and TIG welding prevent distortion for a perfect fit every time. Pans with extended depths reduce temperature and improve oil control during acceleration and braking. They include filter spacers on extended-depth versions where needed. All Moroso transmission pans include dual fittings (except MOR-42050) with magnetic drain plugs and pan
new in the box $200
#2343328 - 07/25/17 08:23 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
gtsdude Offline
Loc: S.E. Minnesota
SOLD For sale A833 aluminum case OD 4 speed and small block bell housing, has cast iron tail shaft with dual shifter mounts,23 spline, came in parts car I bought, had oil in it and turns over by hand in gear. $250 would rather not ship, pick up in Spring Valley MN 55975. PM on board. SOLD
Edited by gtsdude (08/22/17 05:10 PM)
#2343701 - 07/26/17 12:30 PM Re: Mopar Transmission For Sale - 3rd Quarter [Re: 6PAX]
granny53 Offline
Loc: new jersey, usa
PP833 TRANS CASE WITH REVERSE GEAR & LEVER & BACK UP SWITCH DATE CODE 3406 - 11-24 $250. CLIFTON NEW JERSEY 07011 201-618-2758 E-MAIL PTRTESTER@YAHOO.COM SMALL BRG 833 CHRYSLER 4 SPEED BRASS FORKS $60.
#2344107 - 07/27/17 07:18 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
ric3xrt Online   content
Loc: Sellersville Pa
Pair of Big block 727 4x4 truck trans no Transfer cases.
Both pulled 10 years ago, one's a 78 the others a 77.
$400 the pair.
ric3xrt@yahoo.com 267 347 2826.
PM me here , I try and check in here once a week your better off emailing me.
I'll take whatever photos you want just let me know.
Truth has no agenda, but those with an agenda don't always acknowledge truth
1975 D-code D100
1975 D-code Ramcharger
1977 D-code Warlock
1977 D-Code D100
1978 D-code Mid Nite Express
1978 Lil Red
1979 Lil Red
2004 Rumble Bee
2005 Ram GTX
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building
2014 1500 tradesman(shhhh, it's hiding a 6.4 short block under those eagle heads.
#2344171 - 07/27/17 09:10 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1971 to 1974 B-body and 1970 to 1974 E-body NOS shifter boot bezel, part #2996415 $150.00 (708)288-2879 Scott
#2344175 - 07/27/17 09:15 AM Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
426 HEMI 727 torqueflite front drum, rear drum and brand new band, all parts are in excellent condition $750.00 for everything (708)288-2879 Scott
24,831 Registered Members
183,130 Topics
68 b body master cylinder
by road
48 minutes 52 seconds ago
71 'Cuda Curious Yellow 440-6 Show Cars
by Maxwellwedge
Today at 10:29 AM
Which Wix filter to run?
by bubby440
Today at 10:17 AM
Jack Smith; Father of The Plymouth Road Runner, Passes Away
by Rustymuscle
Today at 09:12 AM
