#2337549 - 07/15/17 06:31 PM serious wheel hop
montanamopar92 Offline
Loc: libby mt
Trucks a 81 shorty, d150, built small block. I noticed when trying to "warm" the tires I get some serious wheel hop. I'm running 3 leafs with the very bottom removed so yes the suspension is soft.. Was thinking maybe if I add that bottom leaf back I would loose the problem?? Or if I did slapped bars?? I noticed I see slapped bars for spring under axle an not for spring over axle??
#2338130 - 07/16/17 10:39 PM Re: serious wheel hop [Re: montanamopar92]
tmef Offline
Loc: Independence, KS
I had the same issue with my 83 shortbed. I don't believe adding that bottom leaf back on is going to help out any at all. I went with this 3/4 ton spring from ATS Springs. It rides firm, but not harsh.
#2338303 - 07/17/17 10:25 AM Re: serious wheel hop [Re: montanamopar92]
rustbuckett68 Offline
Loc: Alberta
Would putting the thick bottom leaf back on, but reversed, so the long portion is to the front help? Did that with my gmc, but still not running. Would almost be like a slapper, especially if one could put a bumper on the front segment.
#2338375 - 07/17/17 12:36 PM Re: serious wheel hop [Re: montanamopar92]
stumpy Online   content
Loc: Grand Prairie,Texas
How are your shocks?
#2339397 - 07/18/17 08:58 PM Re: serious wheel hop [Re: montanamopar92]
Grizzly Offline
Loc: at work
Kicker shocks were once available from Direct Connection for those trucks. Rancho was the supplier, I'm sure they can set you up.
SRT-10's used them too..... scope ......I just learned this. work
25,077 Registered Members
185,669 Topics
ID these steering boxes
by mickm
01/20/18 07:15 PM
06 bed fender rust
by cudaman1969
01/20/18 06:20 PM
727 Adjuster screw leaking - O-ring seal fix?
by grancuda
01/20/18 05:43 PM
Grille - Known sources?
by oldjonny
01/20/18 05:40 PM
