Re: New Passon Performance 5 Speed update
[Re: JamiePasson]
#2450106
02/11/18 03:23 PM
02/11/18 03:23 PM
Posts: 1,130 Home of the Bluegrass
MoparJunkie
I just kept my cage crate.... handy to store a trans in.
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: JamiePasson]
#2464868
03/11/18 07:12 PM
03/11/18 07:12 PM
Posts: 36 Alberta, Canada
572hemi
Alberta, Canada
Way to go Jamie, shipping outfits are just bad news
1967 GTX 572 HEMI 735 HP, 717 FT Lb T, , A-855 5 Speed, Dana 60 4:30 Gears, 30" Rear Tires
[Re: JamiePasson]
#2466753
03/15/18 03:16 AM
03/15/18 03:16 AM
Posts: 4,179 California
mickm
California
I have been busy trying to stay on top of stuff. As some realize that this is a job! The reason for the OSB box is we were actually having units getting broken in shipping because there was nothing to absorb the impact of the ridiculous handling of the shippers. That’s the reason and the only reason. We have shipped well over a thousand A833 units in OSB crates and I have had 2 broken. I’ll take those odds.
ALSO, we ran two runs of dual mount 70 up B/E tails and had core shift both times. That is why there is a delay on those units. We expect more tails late April Yes, and I was one of those lucky 2! Luckily we were able to get UPS to reimburse Jamie, and I have only the highest praise for how he handled it for me!
[Re: mickm]
#2467010
03/15/18 06:21 PM
03/15/18 06:21 PM
Posts: 3,680 South San Francisco, Ca
70sixpkrt
ALSO, we ran two runs of dual mount 70 up B/E tails and had core shift both times. That is why there is a delay on those units. We expect more tails late April Yes, and I was one of those lucky 2! Luckily we were able to get UPS to reimburse Jamie, and I have only the highest praise for how he handled it for me! Mick which tranny did you get? I was thinking of getting his overdrive unit.
[Re: 70sixpkrt]
#2467017
03/15/18 06:40 PM
03/15/18 06:40 PM
mickm
California
ALSO, we ran two runs of dual mount 70 up B/E tails and had core shift both times. That is why there is a delay on those units. We expect more tails late April Yes, and I was one of those lucky 2! Luckily we were able to get UPS to reimburse Jamie, and I have only the highest praise for how he handled it for me! Mick which tranny did you get? I was thinking of getting his overdrive unit. I had him rebuild mine. I was having issues I couldn't track down, finally got tired of it, and had him fix it.
[Re: mickm]
#2467041
03/15/18 07:52 PM
03/15/18 07:52 PM
70sixpkrt
ALSO, we ran two runs of dual mount 70 up B/E tails and had core shift both times. That is why there is a delay on those units. We expect more tails late April Yes, and I was one of those lucky 2! Luckily we were able to get UPS to reimburse Jamie, and I have only the highest praise for how he handled it for me! Mick which tranny did you get? I was thinking of getting his overdrive unit. I had him rebuild mine. I was having issues I couldn't track down, finally got tired of it, and had him fix it. How is the tranny now?
[Re: 70sixpkrt]
#2467116
03/15/18 10:32 PM
03/15/18 10:32 PM
mickm
California
Great! I broke a few teeth off of second gear on the cluster gear, reverse had some pretty bad teeth, but the issue I couldn't solve was the input shaft that went into the pilot bearing was not in great shape. Looked good at eye level, so never checked it. He found that and fixed it, and it has been great ever since. Except when it arrived with the input shaft hanging out of the front of the packing case! They slammed that thing around so hard it broke the snap ring boss out of the the tail shaft, so he had to put a whole new one on. They brutalize packages sometimes...
[Re: JamiePasson]
#2515219
06/30/18 10:52 AM
06/30/18 10:52 AM
Posts: 33 Colorado
Slimfish
Colorado
Do you know if the parts supply problem is for all models or just E/Bs? How many folks have waited five years and not received a transmission yet?
[Re: Slimfish]
#2517097
07/03/18 05:36 PM
07/03/18 05:36 PM
Posts: 287 NW Illinois
MoonshineMattK
NW Illinois
Do you know if the parts supply problem is for all models or just E/Bs? How many folks have waited five years and not received a transmission yet? I'm waiting for B/E trans. Not sure if the A-body transmissions are rolling out. Not aware of any other manual transmission that will work as well as the 855. Not interested in cutting up another car to fit a substandard trans. To each their own. I'm willing to wait.
