Re: Small block firecore 50 distributor.
[Re: pjc360]
#2337872
07/16/17 05:17 PM
07/16/17 05:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yeah, go look at the Firecore documentation at their site before you buy. It's almost as craptastic as their website layout. Only reason it isn't as craptastic is because there is none.
Not sure I want to buy something with no idea what is has, or hasn't got.
You can buy it from more than Mancini though.
[Re: Supercuda]
#2337877
07/16/17 05:20 PM
07/16/17 05:20 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
You can buy it from more than Mancini though. that is amazingly annoying too. no sort of documentation at all and very little on Mancini's.
[Re: pjc360]
#2337955
07/16/17 08:08 PM
07/16/17 08:08 PM
mikemee1331
bethlehem pa
I guess I will call Mancini in the morning and start asking questions. the better bet is to contact sunroofgtx. he works for Firecore.
[Re: mikemee1331]
#2337967
07/16/17 08:29 PM
07/16/17 08:29 PM
Posts: 10,550 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have one of the first Firecore distributors in my Savoy and it's just a mag pick-up tall model for RB engines. The advance is easy to adjust with just a Phillips screw driver to loosen the plate. Mine came with about 15* advance and the springs were perfect out of the box for my car. I had to adjust the advance to 10* and it was easy on a big block. There are no measurement tools that I am aware of though I just set mine and checked it and got lucky on the first try. I am very happy with mine and I suggest you leave the springs alone or change them without disassembling the distributor. I changed them on other Firecore units using dental picks and micro needle nose pliers. This distributor is not really meant to be disassembled and the only ones I have seen troubles with are those that have been disassembled to change the springs. Mine has been flawless for almost 8 years now and I would buy another one if I had to. You can get them with either type of cap so make sure you specify with your order. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: pjc360]
#2338269
07/17/17 11:33 AM
07/17/17 11:33 AM
Posts: 79 Europe
rory73
Europe
[Re: pjc360]
#2338362
07/17/17 02:13 PM
07/17/17 02:13 PM
Posts: 653 montana
pjc360
montana
I ordered one this morning from Mancini. I'm running a magnum crate engine, 36-38 degrees of total timing would be too much imo. Mine runs best at around 34 degrees of total timing. I don't need tools to limit the advance because I have the measurements written down for what the slot length should be. I can just find a couple of drill bits and measure them with my micrometer and set it that way. I will leave the springs alone, as along as the timing is all in by 2500-3000 rpm I'll be happy. Do you have to take the reluctor and pick up coil out to set the mechanical advance? I guess if it does come with 20 degrees of mechanical advance I can live with that. Set my initial at 14 degrees and have the total land at 34 degrees. But if it's any higher then 20 then I'll be adjusting it.
[Re: belv2vert66]
#2338436
07/17/17 03:55 PM
07/17/17 03:55 PM
dogdays
Well, boys and girls, here's another result of the consolidation in the performance ignition industry. MSD, which is a Holley corp, bought Mallory some time ago. As you might expect, few Mallory items are being produced any more. If you have an 8BA flathead, you're in luck, you can still buy a distributor. Otherwise the product line is limited to fuel pumps and regulators, two ignition boxes and 82 replacement items for Mallory distributors. There is no ignition curve setting kit among the 82 items.
Rick, Sparky, SunroofGTX are the same guy and as far as I know he IS firecore. He's a board member. Seems to be a great guy who is into making sure his products work. Maybe he needs to start producing the advance setting parts. I wouldn't be surprised to see him on this thread soon.
R.
[Re: dogdays]
#2338695
07/17/17 10:57 PM
07/17/17 10:57 PM
Posts: 4,457 Washington
madscientist
Washington
R. Just another reason to not like MSD.
[Re: pjc360]
#2339141
07/18/17 03:28 PM
07/18/17 03:28 PM
Posts: 1,376 Back In Iowa
belv2vert66
Back In Iowa
I saw the summit kit for 20 bucks last night, but it seems like a waist of money since I already know what the measurements are. Here is what I have written down. 20 degrees of mechanical advance is .185 18 degrees of mechanical advance is .165 16 degrees of mechanical advance is .150 14 degrees of mechanical advance is .130
No one has been able to tell me exactly what the mechanical advance is set at out of the box on a small block fire core distributor, I've been told 20 degrees and I've been told 22 degrees. I've been told the advance rate is all in at 2500 and I've been told it's all in at 2800 and all in at 3000. Guess I'll just have to throw it in right out of the box and put the timing light to get to find out for sure what the settings are out of the box. I don't recall what the base line tune is. I think the install instructions state it tho...........I remember mine needed adjusted to what I wanted to run.
[Re: pjc360]
#2341800
07/23/17 01:54 AM
07/23/17 01:54 AM
Posts: 653 montana
pjc360
montana
I just waned to give an update. I ordered the firecore distributor from Mancini. It arrived pretty quick, bout 3-4 days. It came with the keys to set the mechanical advance and a few different springs to set the advance rate. I left the springs alone that came in the distributor, the two blue springs because that's all in at 2800 rpm and starts to come in at 1200. I set the mechanical advance at 16 degress with the key. The reluctor teeth were all spot on at .008 and remained that way even with the vaccum advance applied, no advance plate wobble what so ever. Very solid unit. Installed it and set my initial timing to 16 degrees, hooked the vacuum advance up to manifold vacuum and checked the timing it was at 30, exactly where I wanted it. Took it for a drive and I was amazed at how smooth it was idling in gear and in park. And it felt more responsive. I wish I would have bought one of these a long time ago. It blows the fbo distributor I had out of the water. Anyone thinking about getting one don't wait another minute, they are worth every penny.
