04 truck 5.7 altenator control? #2335137
07/11/17 02:16 AM
07/11/17 02:16 AM
southern Idaho
moparcyco Offline OP
southern Idaho
Not sure if I should call it control. I have a 04 5.7 truck Hemi going in a 69 Bee. Decided to go holley HP efi it will do everything but control the alternator. I am also using an American Autowire harness witch wants you to use a single wire alternator. Options? Is there an Internally regulated Denso style alt that will work? I need as muck amperage as possible. Or is there a way to wire up the stock 04 to work without an external regulator? I really don't want a gm style alt on this. Any help is appreciated. Thanks
Re: 04 truck 5.7 altenator control? [Re: moparcyco] #2335595
07/11/17 11:06 PM
07/11/17 11:06 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I've used a small Geo one wire alternator but I doubt it would meet you electrical needs.
Re: 04 truck 5.7 altenator control? [Re: moparcyco] #2336433
07/13/17 11:41 AM
07/13/17 11:41 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why don't you just wire in an external regulator? The connector is $25 at rock auto and you can use an old school regulator.
Don't be the exception.
Re: 04 truck 5.7 altenator control? [Re: moparcyco] #2336484
07/13/17 01:57 PM
07/13/17 01:57 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
go with a trasnpo volt reg #IN8315----it goes inside the case of the alternator and turns it into a one wire-----we use them on cummins conversions into older or non dodge trucks---my son buys them 3 at a time on amazon or ebay---dont want to get caught short....
Re: 04 truck 5.7 altenator control? [Re: Supercuda] #2336545
07/13/17 04:11 PM
07/13/17 04:11 PM
southern Idaho
southern Idaho
Filled all the holes on firewall for a clean look. I may end up using one and mount on frame rail or somewhere. Just looking at all options.
