Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Weird MoPar interchangability..... [Re: romanucci] #23354
02/08/06 10:10 AM
02/08/06 10:10 AM
Dallas, Wisconsin
BurntOrange Offline
BurntOrange  Offline
Dallas, Wisconsin
My girlfriend . . now wife fit the back seat of any Mop . .
Oh . . wrong forum.
I'm hoping to find roofrail channel weatherstripping from another model that will fit my '69 Fury 2dr hdtp formal (sport) roof.
Re: Weird MoPar interchangability..... [Re: ph23vo] #23355
02/08/06 10:14 AM
02/08/06 10:14 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
fury turn signal lenses fit superbirds...
69 Valiant turn signal lenses fit Daytona Chargers!
JB Rhinehart, Realist
A-Body's RULE!
Re: Weird MoPar interchangability..... [Re: 68Cbarge] #23356
02/08/06 10:17 AM
02/08/06 10:17 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Where is the guy who put a 70 dart rear bumper/valence panel on his 76 dart??? :
He is usually in here.
Well, it wasn't a direct bolt in, but we made it work.
See pics here http://www.breakstuffracing.com/6901.html
Re: Weird MoPar interchangability..... [Re: romanucci] #23357
02/08/06 10:50 AM
02/08/06 10:50 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
2.2L K car alternator with V belt. Direct bolt in.
hmmm what output rating do they have .
I'm curious about that one, too. Does the K-car alternator still have an external regulator? Is it one field wire or two?
It's probably just the same as most any of the square-back ALT's. It's two wire, and externally regulated. Probably something like 60A, which is about what you get from the parts hous if you ask for a 74 Swinger 318 with A/C...
My 86 Shelby Charger uses a similar looking ALT, also square back and dual wire externally regulated. It's got a thin metal ring in the middle, like 1/8" wide, where the "normal" old-skool ALT is about 1/2" wide. This is supposedly a higher-rated ALT, but I don't recall how high. That one would require a pulley swap, but I bet it's a direct swap. FWIW, the power module behind the battery is what controls the ALT output. Mine took a dump a bunch of years ago, and I simply pulled the two wires that that ran the ALT and plugged them in to a typical fender-mount electronic regulator. Worked great for a few years until I found another good PM.
Also, the REAR dust caps, nuts, key washers, and adjuster nuts on Dodge Daytonas (87-89 at least) are perfect fits for the FRONT dust caps on big bolt pattern disks, AKA, Darts, Challengers, and the cop rotors.
Clair
Re: Weird MoPar interchangability..... #23358
02/08/06 11:28 AM
02/08/06 11:28 AM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
Turn signal switch and canceling cam from up to 1976 Dodge Vans will work in a 65' Coronet Steering column.
With no modification? Do you know the Part number? Would like to try that at a dealer.
Re: Weird MoPar interchangability..... [Re: 65Frank] #23359
02/08/06 11:37 AM
02/08/06 11:37 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Me three!
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23360
02/08/06 11:52 AM
02/08/06 11:52 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Another good one is every mirada I've seen has a rear side marker lens that has SAE # 73 or 74, like maybe old C body part or something.
Re: Weird MoPar interchangability..... [Re: buildanother] #23361
02/08/06 12:29 PM
02/08/06 12:29 PM
Rhinotruck
Rhinotruck
The 72-up marker lights were used all the way up to the 96 Dakota!
A-Body's RULE!
Re: Weird MoPar interchangability..... [Re: Rhinodart] #23362
02/08/06 12:41 PM
02/08/06 12:41 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
68 GTS hood inserts (and at least part of the hood) showed up around 74 on Brazilian Chargers...........
Re: Weird MoPar interchangability..... [Re: Jim_Lusk] #23363
02/08/06 01:35 PM
02/08/06 01:35 PM
Lubbock, TX
slantvaliant Offline
Lubbock, TX
Hemi spark plug tube gaskets fit the drool-tube slant sixes.
Re: Weird MoPar interchangability..... [Re: slantvaliant] #23364
02/08/06 02:15 PM
02/08/06 02:15 PM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Yep. The exhaust flang gasket for a slant is also the same part number for a 440. Ford fuel tank floats work for our Mopars also.
Eric
Re: Weird MoPar interchangability..... [Re: KillerBee] #23365
02/08/06 02:38 PM
02/08/06 02:38 PM
thats a great one killer bee! Thank you!! I didnt know that. Do you know about the same dodge truck years for the side parking light or marker light. I think they fit 71?-75 b-bodies as well.
Re: Weird MoPar interchangability..... #23366
02/08/06 03:27 PM
02/08/06 03:27 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Heater controls (the dash mounted part) will swap between late '70's B-bodies and early '80's trucks with no mods at all. I had an '84 PU that I swapped in the controls from a '76 Fury.
John
Re: Weird MoPar interchangability..... [Re: romanucci] #23367
02/08/06 03:32 PM
02/08/06 03:32 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
2.2 pistons can be used in a Slant 6.
Re: Weird MoPar interchangability..... #23368
02/08/06 04:19 PM
02/08/06 04:19 PM
chicagoland,usa
chicagoland,usa
I know the 72 surface mount side marker lights fit all kinds of later mopars, but rhino is not going to find one of those on a dakota. I would say he's been sniffing too much solder flux at work but he does'nt really work at work!
Re: Weird MoPar interchangability..... [Re: buildanother] #23369
02/09/06 03:39 AM
02/09/06 03:39 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
70-71 Fury side marker lenses and reflectors are the same as those in a 70-71 cuda
70-71 Fury front side marker bezels are the same as a 70-71 cuda rear side marker bezel (Except Sport Fury, those are completely different)
69-71 Fury dome lights are the same as those used in any E-body with the overhead console
70-74 E-body console latches are the same as a mid-late 70's Dodge Truck or Van glove box latch
70-71 Dart side marker mouting brackets are the same as a 70-71 Challenger
70-71 Dart uses the same 100 Jack hook as a 70-71 cuda
slant six starter gasket/shield is the same as a big block
71-74 B or E-body mirror heads are the same as those used on 75-79 Cordoba/Aspen/Volare/etc. (The bases are different.)
Re: Weird MoPar interchangability..... [Re: Barnabas_Kriss] #23370
02/10/06 11:48 AM
02/10/06 11:48 AM
Was there a post like this some time ago. This is great stuff.
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23371
02/10/06 07:21 PM
02/10/06 07:21 PM
Tracy, New Brunswick, Canada
magnumcharger Offline
I can verify the 73-74 Dart/69 Barracuda hood swap...did it.
How about BigBlock "umbrella" valve seals for windsheild wiper post gaskets on 66-70 B bodies....
Or A-100 seats in Superstockers?...
Or 70 Charger Hoods and fenders on Daytonas, as well as 70 Coronet hoods and fenders on Superbirds?
Or, the door glass on a 68-70 Coronet/Belvedere also fits 68-70 Chargers?
Pretty well ALL of the consoles in B and C bodies of each year are the same...
Back-up lights on a 69 Roadrunner bumper...same as 69 Charger rear valance...(?)
Almost all 1969 Chryco vehicles have the same side reflectors....
Re: Weird MoPar interchangability..... [Re: Chris2581] #23372
02/10/06 07:29 PM
02/10/06 07:29 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Dodge truck hood hinges are also the same as B-body hinges.
Differnt spring
Re: Weird MoPar interchangability..... [Re: copper67440] #23373
02/11/06 12:37 AM
02/11/06 12:37 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
anyone know if a 74 abody console button would interchange with something a little more common?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
